Acum este Sâm Iul 19, 2025 4:05 am
 Subiectul mesajului: Sfat pt incinta subwoofer cu dif 18"
MesajScris: Joi Sep 09, 2010 11:00 am
Am observat o pricepere deosebita din partea dvs. in acest domeniu(incinte acustice) si cred ca aveti bunavointa de a ma ajuta cu o mica informatie!
Ma intereseaza o schema de incinta cat mai potrivita pt dif Eminence OMEGA PRO-18A
Nominal Basket Diameter 18", 457.2mm
Nominal Impedance* 8 ohms
Power Rating
Watts 800W
Music Program 1600W
Resonance 25Hz
Usable Frequency Range 40Hz-800Hz
Sensitivity*** 97
Magnet Weight 109 oz.
Gap Height 0.375", 9.53mm
Voice Coil Diameter 4", 101.6mm
THIELE & SMALL PARAMETERS
Resonant Frequency (fs) 25Hz
DC Resistance (Re) 5.20
Coil Inductance (Le) 1.67mH
Mechanical Q (Qms) 8.18
Electromagnetic Q (Qes) 0.32
Total Q (Qts) 0.31
Compliance Equivalent Volume (Vas) 548.7 liters / 19.4 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 556cc
Mechanical Compliance of Suspension (Cms) 0.29mm/N
BL Product (BL) 18.8 T-M
Diaphram Mass inc. Airload (Mms) 138 grams
Efficiency Bandwidth Product (EBP) 79
Maximum Linear Excursion (Xmax) 4.8mm
Surface Area of Cone (Sd) 1159.0 cm2
Maximum Mechanical Limit (Xlim) 16.0mm
http://eminence.com/proaudio_speaker_de ... B_CAT_ID=1
Cabinet Design:
http://eminence.com/pdf/cab-omegapro-18a.pdf
Multumesc anticipat!
MesajScris: Joi Sep 09, 2010 11:44 am
subwooferul va fi fix sau mobil?
MesajScris: Joi Sep 09, 2010 3:39 pm
Sa fie cat de cat mobil, sa-l pot scoate din casa, transportabil intr-un papuc sau break la evenimente, sa poata fi dus de 2 persoane maxim.
In functie de raportu: randament/greutate/volum pot face 1 sau 2 bucati, momentan am doar un dif.
Multumesc!
MesajScris: Joi Sep 09, 2010 4:46 pm
http://www.forumpoweraudio.ro/viewtopic.php?t=5143
il poti construi fara nici o diferenta fata de proiect pentru difuzorul tau
 Subiectul mesajului: Re: Sfat pt incinta subwoofer cu dif 18"
MesajScris: Mar Noi 23, 2010 12:21 pm
Multumesc!
