Acum este Joi Iul 17, 2025 2:27 pm
Scrie un subiect nou Răspunde la subiect  [ 79 mesaje ]  Du-te la pagina 1, 2, 3, 4, 5, 6  Următorul
 Subiectul mesajului: Design Parameters
MesajScris: Mie Noi 16, 2005 6:36 pm
Localitate: Southampton, UK
Ooooh, I feel honoured to post the first topic! (Edit: Or not, Nexus3 posted while I was writing this!)
Let's start with the basics, what do we want this mid-top to do? Here's my take on it:
Frequency range: 120Hz -> 20kHz
Dispersion: Not certain, but 60x40deg would be sensible, we're not designing a line array! Must be arrayable obviously.
Cabinet: Dispersion above leads to 15deg trap sides. Must be managable by two men or less, ie aim for 60kg max.
Topology: I reckon 8PE21 for mids and DE250 for tops but undecided on low mids between 1or2 12" or 15".
Applications: Useable from one cab per side for medium sized venues for general purpose live/DJ events.
Please post your thoughts on what this box should do, hopefully we can come to some agreement on specification.
MesajScris: Mie Noi 16, 2005 6:43 pm
I think your requirements are perfect, but I have some improvements maybe,
we should make the cab go lower if possible, (I have the punisher design subbass in mind, so 100Hz would be perfect if we could get it in that region...)
MesajScris: Mie Noi 16, 2005 7:13 pm
Localitate: Michigan, US
Concept sounds pretty right on.
Component selection shouldn't be locked in yet. The units listed are good, but we should see what else is out there. We should also have some alternatives for folks in different areas and finicial status.
Jim
MesajScris: Mie Noi 16, 2005 8:53 pm
i think we should try and aim for a tighter dispersion than the 'obvious' 60x40. whilst this is ideal for a stand alone mid top it is harder to use for suitable trap cabs for arraying. symetrical dispersion allows for more simple horn construction, possibly with the benefit of less colouration, so what does 40x40 sound like on a 10 degree box angle?
from my understanding a well designed phase plug besides boosting efficiency in the higher mids, can also help tighten up the dispersion in those frequencies. having seen the polar plots for the porn horn i think we should set our sights on something that gets this bit right, i reckon we'll struggle less with a nice tight dispersion. also, good for outright spl.
james.
MesajScris: Joi Noi 17, 2005 10:51 am
Ok, I'm happy to go for 40x40. Means for that you might have coverage problems if you only take out one per side but I guess you'd have alternative problems trying to put multiple wide dispersion boxes together.
MesajScris: Joi Noi 17, 2005 7:48 pm
Localitate: Italy
Actually a 40x40° dispersion pattern is pretty useless for single use. You'll always need at least 2 cabs for proper coverage.
I'm for 60x40. There are much more top horns with such dispersion pattern.
MesajScris: Joi Noi 17, 2005 7:53 pm
Localitate: Italy
Going really low mean using 2x15" bandpass or a really long horn (at least 70cm).
I think 110-120hz is much better, consider many commercial products go down to 120-150hz, not lower.. The most of subs can go high to 120hz without problems (commercials, wsx, 1850, hd15, bp18, and so on).
MesajScris: Joi Noi 17, 2005 10:10 pm
I think you need to make your mind up whether you want a box that you can use 1 of, or a box that you can easily array.
If you're only going to use 1 box a side then you may as well forget trying to array them at all and go for a straight sided wide dispersion box.
MesajScris: Joi Noi 17, 2005 10:31 pm
I personally would like a box that could work in singles as compact as possible
I am curently working at a compact trapezoidal box using
2xWN-15S P-audio in 6th order bandpass
2x8PE21 B&C waveguide loaded
1xBM-D450 P-audio Waveguide loaded
the design looks like this:
plans are curently on paper because I suck at Autocad :oops:
dispersion would be about 60x40
it's designed for using with the punisher subwoofer
MesajScris: Joi Noi 17, 2005 10:33 pm
i agree dom, seeing as there is the x-tro doing the stand alone job, not forgetting that there is plenty of room for evolution of this quite young design, i think we should go for the narrow dispersion super pokey array cab. this is not on offer elsewhere.
i am aware of the lack of 1" horn flares that meet the requirements, it may be appropriate to build what we need.
james.
MesajScris: Joi Noi 17, 2005 10:38 pm
Localitate: Italy
Yes i think it's better to think if we're doing a project to be used as standalone, as array or a compromise.
Let's take a look at arrayable pro cabs dispersion pattern (HxV):
Martin Audio W8: 55°x30°
Martin Audio W8C: 55°x30°
Martin Audio W3: 65°x40°
Proel Edge 212P: 50°x40°
Turbosound THL-811: 55°x40°
Turbosound THL-4: 55°x40°
EAW KF-850: 55°x40°
And so on...
It looks to me 55°x40° is the way to go...
what's going on inside that magic box then nexus?
james.
MesajScris: Joi Noi 17, 2005 10:46 pm
Localitate: Italy
Nexus... this is a copy of Outline Doppia!!!!!!!! :?
well, James, behind the waveguides there are two neoodymium 15" woofers which have each 102.2 dB spl @1W :twisted:
it's a 6th order bandpass designed to work between 70 and 350Hz flat :wink:
work at the prorotype will start as soon as I sort out the 10 liters of volume that I can't seem to find room for:roll:
the 15"-ers are really stretching their luck inside this cabinet :lol:
nu quite
but an improved version :wink:
Doppia uses 12" ferite speakers
there's no shame in taking apart a werry good speaker and trying to improve it 8)
