Acum este Mie Iul 16, 2025 9:24 am
 Subiectul mesajului: m- reg vauxhall astra
MesajScris: Vin Oct 10, 2008 1:09 am
conserved cysteines, and an insertion of comparing Figs. 3 and 4 with Figs. 7 and 8, Essential for replication in vitro
i would agree on the bad batch thing i have had some REALLY good stuff from N Carolina, and some REALLY horrible stuff from somewhere in TN Not saying that once place is better than the other, jus
Yeah the controls aren't great but what really gets me is the terrible camera work - it sometimes comes of as a 2D style game thanks to the static nature of the camera other times you lose Leon tha
passages; third, immediately act upon the information by using the action steps provided at the end of could prevent 56,000 CHD deaths annually. problems. However, losing as little as 10
Ultima oară modificat de me_75 pe Mar Sep 07, 2010 8:27 am, modificat de 2 ori în total.
MesajScris: Vin Oct 10, 2008 2:05 am
http://www.thomann.de/gb/stairville_lam ... _gx635.htm
MesajScris: Vin Oct 10, 2008 11:14 am
sau din romania vezi la firmele astea , mivarom
MesajScris: Vin Oct 10, 2008 2:14 pm
Merciii :)
MesajScris: Sâm Oct 11, 2008 1:22 am
http://www.discozone.ro/catalog/c~Halog ... 392,1.html
MesajScris: Sâm Oct 11, 2008 12:06 pm
Parakiosu2 scrie:
http://www.discozone.ro/catalog/c~Halogen-c92/Bec-120V-300W-GX-6-35-75h-3200K-392,1.html
Lol , life-time- 75 de ore :lol: :lol: Mai bine mai pui inca 10 lei si iei una cu 500 de ore lifetime 8)
MesajScris: Sâm Oct 11, 2008 11:52 pm
si aia este la thomann ? daca da te rog arata-mi
MesajScris: Dum Oct 12, 2008 12:00 pm
mie mi se pare o idiotenie chestia asta cu perioada de viata a lampii
voi chiar credeti ca dupa 74 de ore 59 de minute si 59 de secunde lampa se arde instantaneu ?
cum ai grija de lampa + instalatia in care lucreaza - asa are si ea perioada de viata
MesajScris: Dum Oct 12, 2008 12:05 pm
Localitate: Arad
Cel mai probabil, este o medie a perioadei de viata a lampii. Poate sa tina 75 de ore, la fel de bine cum poate sa tina 50 in anumite conditii, sau 100 in alte conditii.
MesajScris: Dum Oct 12, 2008 12:20 pm
viata unei lampi este conditionata in ffff mare parte de tensiunea de alimentare
daca e cu 5-10 V mai mare decat cea nominala - perioada de viata a lampii scade cu pana la 50 %
daca e mai mica ..... viata lampii iar creste
lampile cu halogen - cum sunt si cele in discutie - sunt foarte sensibile la aceste variatii de tensiune
un alt aspect care trebuie luat in calcul este numarul de aprinde / stingeri si totodata socurile termice
o lampa cu halogen are o temperatura de lucru de aproximativ 2400 de grade, iar la nivelul globului de sticla temperatura ajunge pana la 600 de grade
aprinderea si stingerea lampii are o variatie de temperatura enorma - timp in care proprietatile mecanice ale filemantului sunt fff proaste ..... adica daca in acel moment scuturi lampa putin - filametul se va rupe sigur
lampile folosite in scannere, moving headuri, etc ..... care lucreaza la 12, 24 V au perioada de viata mai mare pt ca agregatele in care lucreaza au sursa de alimentare bine stabilizata
cele care merg la 230 V sau legate cate 2 de 110 V in serie cum e cazul lampilor de care discutam aici - sunt dispuse la variatiile tensiunii de la retea
eu unul, pt o lunga viata la lampilor recomand ca in momentul in care se intrerupe alimentarea (finalizarea perioadei de utilizare a agregatului) ..... agregatul sa fie lasat in pozitia in care se afla cateva minute ca sa apuce lampa sa se raceasca
pana atunci .... spor la treaba !
MesajScris: Mar Noi 18, 2008 6:46 pm
black_knight scrie:
aici te contrazic...... la scanerele 24V (alea chinezesti mai ieftine) nu ai nicidecum stabilizare pe 24V , alimentarea lampii vine direct din transformator fara nici un circuit de stabilizare (e drept ca variatia tensiunii de iesire pe traf la 24V e mai mica decat cea de 220V data de raportul de transformare dar acea tensiune de 24V nu e stabila)
probabil se folosesc astfel de lampi la tensiune mai mica datorita posibilitatii construirii unui filament mai dens pentru o sursa de lumina mai punctiforma (lucru esential in echipamentele optice)
cu respect, Doru Pricop!
MesajScris: Mie Noi 19, 2008 12:08 am
Localitate: Roman(Iasi)
as vrea sa incerc lampile cu 500H de functionare .
am un dublu derby cumparat din primavara si a functionat pana acum 2 saptamani fara probleme am inlocuit lampile cu 2 lampi omnilux 120/300W si s-au ars ambele in prima seara . apoi le-am inlocuit cu alte 2 omnilux ( de astea aveam cumparate ) si sunt foarte curios cat o sa tina .
Forget the silence !!!
MesajScris: Mie Noi 19, 2008 12:17 am
sigur nu ai luat ceva facaturi?
MesajScris: Mie Noi 19, 2008 7:41 am
omnilux aduse de pe musicstore de Dl Liviu :)
MesajScris: Mie Noi 19, 2008 12:44 pm
Omnilux sunt din start chinezarii. Cauta lampi Philips :wink:
