Acum este Mar Iul 01, 2025 7:44 pm
 Subiectul mesajului: line array
MesajScris: Vin Noi 03, 2006 10:31 pm
Localitate: Serbija
line array top project
speakers project
MesajScris: Sâm Noi 04, 2006 9:52 am
it uses:
P-audio P10/100MB for midbass, horn loaded (90Hz - 400Hz)
Beyma 5G40ND for Mid , Horn loaded (400Hz - 3000Hz)
http://prescomaudio.com/pdf/BEYMAPDF/5G40Nd.pdf
P-audio WN-D44 on PH14525 Line array horn - for high frequency (3000Hz - 20 000 Hz
everything is horn loaded , an everything is in a compact package 700/350/450 mm W/H/D
a single unit should be capable of about 126-127 dB continuous from 90-20000 Hz
Punishers would take care of the 40-90Hz region
MesajScris: Sâm Noi 04, 2006 3:19 pm
Localitate: Serbija
this project is excellent,and it is quite satisfactory to me.Can you please send me exact measures,especially inner dimensions,if you have it,or can you direct me to a website or some manufacturer where they can be found.Best regards,Nenadd
speakers project
MesajScris: Sâm Noi 04, 2006 5:03 pm
the drawing is made to scale
1 square is 5 cm
it is a preliminary design made by me
a prototype has not been yet made , so there are no other plans for it
 Subiectul mesajului: TTS28A
MesajScris: Joi Ian 11, 2007 12:59 pm
Hello, i need RCF TTS28A speaker enclosure details, can anybody help me pls?....
Thanks
MesajScris: Joi Ian 11, 2007 3:17 pm
Nexus what horisontal dispersion you will have in the bas & midbas frequency range ?
I ask you because I have read a post on another forum where it was saying: the horn loaded bas boes have a very small dispersion angle; and iti was talking about HD15. It vas saying thatif yu have 8 pieces and you put them in vertical array, the horizontal dispersion angle will be verry small, and you will have a greater angle only by putting them all on the ground, in a horizontal array... :roll:
I saw that Martin Audio has line arrays like these ones ( full horn loading ), but other companies have the classic bassreflex... :roll:
MesajScris: Mar Oct 21, 2008 9:50 pm
http://www.next-proaudio.com/product_in ... ducts_id=3
cine pe cine ? :lol:
MesajScris: Mar Oct 21, 2008 10:32 pm
citat de pe pagina lor cu acel produs:
This product was added to our website on Monday 05 February, 2007.
data postarii proiectului de catre mine:
PostPosted: 04 Nov 2006 09:52 am
deci ei m-au copiat pe mine
mda.. :roll: :?
MesajScris: Mie Oct 22, 2008 4:18 pm
nu cred ca are inportanta cand o fost postate, ci cand au fost proiectate.
Si ma mir sa te fi copiat cineva.
:roll:
MesajScris: Mie Oct 22, 2008 4:48 pm
copiile se practica la greu in domeiul asta.
am vrut sa-i demonstrez la adi ca nu eu am copiat pe ei, ci, daca ar fi fost cazul ar fi fost invers.
oricum, array-ul de la NEXT nu are midbass-ul impaturit ca la mine, e doar un manifold simplu, difuzorul este vizibil din exterior.
fie vorba intre noi, forumul asta este urmarit de f multe persoane din afara Romaniei.
eu pot vedea asta cu ajutorul counterului de trafic, care inregistreaza si locatia geografica a celor care acceseaza forumul.
MesajScris: Mie Oct 22, 2008 11:41 pm
ma gandesc ca o firma serioasa, are angajati ingineri, in acustica si tot felu de tipi scoliti, nu fura de la niste papagali din romania. Sincer.
Aici vb la modu general, nu va infoiati. :D
MesajScris: Mie Oct 22, 2008 11:50 pm
Localitate: Pitesti
greu sa nu faci asta... reiese ca il consideri papagal pe nexus...indiferent ce crezi :) stiu ca nu asta gandesti dar asa se intelege.. si tine minte ca nu toti romanii sunt idioti ... sunt ca si pe la altii destui cu minte .. e imposibil sa fim toti retarzi si sa nu fie si varfuri..
MesajScris: Joi Oct 23, 2008 12:38 am
... in sensul ca din punctul lor de vedere noi suntem niste papagali.
vina manelistilor aici.
+ ca poate au fost ideea lor si faza cu nexuse e doar o coincidenta.
MesajScris: Joi Oct 23, 2008 12:57 am
mackie scrie:
:D
Nici o firmă seriosă nu ţine angajaţi ingineri proiectanţi, decât dacă este un Harman sau EVI Audio, ori alta la fel de mare.
Proiectanţii din acest domeniu 8 cei care contează ) sunt foarte scumpi şi nu se justifică să îi ţii pe ştatul de plată. De obicei se folosesc serviciile unor birouri de proiectare şi consultanţă specializate. Aceste companii mici sunt compuse din câţiva meseriaşi, care se ocupă de proiect. Pentru o firmă care se ambiţionează să ţină "on-house" R&D-ul, poate avea costuri anuale de circa 750.000 - 1.000.000 USD.
Proiectarea unui line array este redusă din star doar la câteva soluţii tehnice.
Prin raţionalizare, se ajunge cam la aceleaşi forme şi dispuneri ale difuzoarelor, dat fiind limitarea opţiunilor.
Este normal ca mai mulţi oameni să ajungă la aceleaşi soluţii, pe căi diferite.
MesajScris: Joi Oct 23, 2008 1:05 am
adircf scrie:
Nu este chiar aşa.
În domeniul acesta există foarte multe orgolii, dar atunci când oamenii văd că eşti priceput şi vorbeşti pe limba lor, te tratează de la egal la egal, fără acele figuri de Buftea, cu care suntem obişnuiţi prin ţară.
Am avut ocazia să cunosc câţiva meseriaşi şi pot să vă spun că nici unul nu era genul de om dispreţuitor sau figurant. Nici pe departe nu m-au tratat ca pe unul venit din Europa de Est, sau ca pe un fel de om inferior.
Pur şi simplu, în momentul când am început să discutăm despre tehnică, orice barieră culturală sau de imagine s-a spart instantaneu.
Nu acelaşi lucru îl pot spune despre cei de la vânzări.
