Neavand suficienti bani ca sa imi iau un amplificator ''Ecler'' am luat urmatorul amplificator:
http://i37.tinypic.com/sdfqma.jpg
cu urmatoarele specificatii in cartea tehnica:
Out Power (8 ohmi) - 2x200 W
Out Power (4 ohmi) - 2x350 W
Out Power Bridge (8 ohmi) - 650 W
Out Power Bridge (4 ohmi) - 950 W
Frecquency Response @ Half Pwr - 15 Hz - 25 KHz (+0/-1 dB)
THD+Noise @ 1 KHz Full Pwr - <0.03 %
IMD 60hz & 7 KHz, 4:1 - <0.038 %
Signal to Noise Ratio - > 102 dB
Slew Rate (input filter limited) - 40 V/uS
Damping Factor 1Khz@8 ohm - >400:1
Input Sensitivity - Selectable (0.77/1.0/1.44 V)
Input Impedance - 10 khom Balanced tu ground
Input Conectors - Female XLR-3 & 6.35mm TRS Jack
Output Circuit Type - Class AB
Output Connectors - 4 Pole SPEAKON & Binding posts
Protections: Full short-circuit, Open-circuit, Thermal, Soft-start, DC Voltage, Sub/Ultrasonic and RF
LED Indicators (per channel) - Bridge, Parallel, Power, Signal, Clip, Protect
Panel Controls - Front-2 input attenuators, Rear - Ground lift, mode selection, compressor
Cooling - Front-to-back via 2 variable-speed fans
Power Supply Voltage - 220V AC/50 Hz
Power Supply Fuse (250V) - 5 A
Dimensions (mm) - 482x383x88.8
N Weight/G Weight (kg) - 14.5/15.5
Amplificatorul a costat 700 RON . Va rog daca puteti sa imi spuneti daca purerea lui este reala(si alte pareri despre el).
P.S.(PT ADMIN): Nu vreau sa fac reclama firmei de unde l-am cumparat vreau dor niste simple pareri despre el
Multumesc anticipat
