Acum este Mar Iul 15, 2025 10:19 am
 Subiectul mesajului: JBL MPX600 vs. PHONIC MAX2500 :)
MesajScris: Sâm Feb 09, 2008 1:26 pm
Localitate: onesti
salut
vreau sa va aud si parerile voastre in legatura cu aceste 2 amplificatoare
jbl mpx600 :
MPX600
l 850 Watts/CH into 2 Ohms
l 600 Watts/CH into 4 Ohms
l 1700 Watts Bridged-Mono into 4 Ohms
l 1200 Watts Bridged-Mono into 8 Ohms
modelul e aparut in 2001 , poze desfacut aici http://www.forumpoweraudio.ro/viewtopi ... ht=jbl+mpx
DlSTORTlON @ RATED POWER
1 kHz, 8 ohm load (typical): 0.015%
1 kHz, 4 ohm load (typical): 0.030%
20 Hz - 20 kHz, 8 ohm load: 0.15%
20 Hz - 20 kHz, 4 ohm load: 0.2%
Frequency Response: 20 Hz to 20 kHz, ± 0.15 dB
Damping Factor: Greater than 200 at 8 ohms
Dynamic Headroom: 2.5 dB at 4 ohms
Noise: 100 dB below rated output (20 Hz to 20 kHz)
Sensitivity: 1 V rms for rated power (8 ohms)
Input Impedance: 10 K ohms unbalanced, 20 K ohms balanced
Amplifier Protection:
Full short circuit, open circuit, ultrasonic and RF protection, current limiting, thermal muting; stable into reactive or
mismatched loads.
Load Protection:
On/off muting, DC fault load grounding relay with internal fault fuses
Power Requirements: 100 V, 120 V, 220 V, or 230 V AC, 50-60 Hz (not user configurable)
la Phonic nu mai e nevoie de specificatii
eu as merge pe jbl voi ce parere aveti in legatura cu specificatiile lui
sharky astept o parere
crexy
MesajScris: Sâm Feb 09, 2008 2:55 pm
as merge pe JBL (din punct de vedere al performantelor )
daca bine retin seria aceea de amplificatoare a fost produsa in regim OEM de catre QSC in state.
vorbim de amplificatoare din lumi diferite.
MesajScris: Dum Feb 10, 2008 12:35 am
Localitate: Bucharest
JBL-ul arata mult mai bine inauntru.
As merge pe JBL daca ambele amplifuri ar fi SH, dar daca Phonicul e nou....l-as lua fara ezitare.
MesajScris: Dum Feb 10, 2008 12:45 am
Da’ juniorul FIDEK nu-l iai în considerare?
MesajScris: Dum Feb 10, 2008 12:53 am
Localitate: onesti
Gizmo scrie:
nici chiar asa :lol:
cel mai low l-am considerat pe max2500 , sub nivelul asta nu cobor
prefer sa dau un ban in plus decat sa ma fac de kkt pe la vrun chef
crexy
MesajScris: Dum Feb 10, 2008 1:38 am
Nu prea stiu ce sa iti recomand.
Ultima oară modificat de Sharky pe Vin Apr 10, 2009 10:18 am, modificat 1 dată în total.
MesajScris: Dum Feb 10, 2008 1:25 pm
Localitate: onesti
astea sunt pozele pe care le am cu el desfacut:
crexy
MesajScris: Dum Feb 10, 2008 4:40 pm
LE-am vazut, pe baza lor mi-am dat cu parerea.
Incearca sa dai si detaliile pe care ti le-am cerut.
MesajScris: Dum Feb 10, 2008 6:05 pm
Localitate: onesti
am specificatii in format pdf dar nu stiu cum sa-l atasez
crexy
MesajScris: Dum Feb 10, 2008 6:13 pm
Localitate: Zalau/Cluj
www.speedyshare.com
Music is my drug
MesajScris: Dum Feb 10, 2008 6:37 pm
man, nu specificatii.
Zi ce tranzistori sunt acolo si cati sunt la numar ca sa iti pot spune daca e mai rezistent sau nu decat phonic.
Eu din cate am vazut pana acum as merge pe jbl.
MesajScris: Dum Feb 10, 2008 9:33 pm
imi place transformatorul :wink:
MesajScris: Dum Feb 10, 2008 9:34 pm
ai vazut un 3600 vz desfacut ? :shock: :D
MesajScris: Dum Feb 10, 2008 10:30 pm
baga niste poze ce mai stai :shock: :shock: :roll: :oops:
MesajScris: Dum Feb 10, 2008 11:00 pm
Localitate: onesti
mariusradulescu1990 scrie:
hai ca bag eu cu fratele mai mare 5000vz :twisted:
http://tinypic.com/view.php?pic=t6tncp&s=3
http://tinypic.com/view.php?pic=dmab2u&s=3
http://tinypic.com/view.php?pic=11vjwuc&s=3
crexy
