Acum este Joi Iul 17, 2025 6:40 am
Scrie un subiect nou Răspunde la subiect  [ 35 mesaje ]  Du-te la pagina Anterior  1, 2, 3  Următorul
MesajScris: Lun Ian 21, 2008 11:18 am
Extras din pdf de la xp 5000
Dual mono, high current power supply for increased reliability and performance
High-current toroidal transformers for greater two-ohm power and low noise
Eu zic ca e bine 8)
MesajScris: Lun Ian 21, 2008 11:50 am
pai ce sa zic...
Atunci e bine.
Ultima oară modificat de Sharky pe Vin Apr 10, 2009 9:19 am, modificat 1 dată în total.
MesajScris: Lun Ian 21, 2008 12:32 pm
There are two standards that make it easier to compare amplifier output ratings the FTC and EIA ratings standards.
The FTC standard was established by the Federal Trade Commission and requires that a manufacturer’s stated power ratings must meet the advertised frequency range (usually 20 Hz to 20 kHz) at the rated THD (Total Harmonic Distortion) with both channels driven.
The EIA rating, established by The Electronic Industries Association, is the power output of a single channel driven at typically 1 kHz with 1% THD clipping. The EIA standard will typically be 10 to 20% higher than the FTC ratings.
We go one step further than the EIA ratings and drive both channels as we feel the fairest, most honest, and most revealing rating method is the obvious one: to specify power with all channels fully driven, as this is a more real world scenario. When fewer channels are being tested, the more power the ones that aren’t being used can deliver. This can artificially increase the apparent power output. By testing with both channels driven we are decreasing the standard 10-20% difference of one channel driven.
What does a 10-20% power difference mean in reality? For the average person to hear a difference in loudness/level, you would need to double the power to the speakers. You can hear the difference between 200 watts and 400 watts, a 3 dB increase or doubling of power, but you won’t hear a difference between 200 watts and 240 watts as small difference in output power are not discernable to the human ear.
To put it in a nut shell we basically provide a more conservative power spec of the EIA standard because we test with both channels driven during our tests not just one.
De pe forumurile de la Crown unde se discuta despre xti 4000- http://www.crownaudio.com/forums/index. ... topic=2088
Din ce zic ei standardul actual de masurare a puterii pt amplificatoarele pro este EIA, este bullshit sau ce?
MesajScris: Lun Ian 21, 2008 12:42 pm
Localitate: Cluj - Napoca
Si, cica, puterea reala:
http://www.crownaudio.com/forums/index. ... ost&p=7654
MesajScris: Lun Ian 21, 2008 12:48 pm
EIA este standardul de masurare la 1khz
MesajScris: Lun Ian 21, 2008 1:03 pm
Sandu_Alex_999 scrie:
Most manufacturers, however, don’t publish a 2-ohm FTC spec even if the amplifier can easily handle normal program material into a 2-ohm load. An FTC rating requires that the amp undergo a "warm-up" test, meaning the amp’s output ratings are measured after 60 minutes at 1/3 power and five minutes at full-rated power. Since 2-ohm operation is right on the edge of where an amp’s current-limiting protection circuits will kick in, the amp will automatically go into protection mode before the five-minute threshold. Fortunately, music waveforms are less demanding than constant-level sine waves or pink noise used for testing. Because of this, most manufacturers only list the EIA power rating for 2-ohm operation.
de aici -> http://www.soundandsong.com/Issue004/00 ... tings.html
Pana la urma toti producatorii dau cifra cea mai mare in reclame, doar ca unii publica si ftc-ul direct.
Crown mi s-au parut f.OK ca au postat pe forum puterea FTC, nu stiu cati altii publica cifrele astea pt amp-uri aproape low-cost.
MesajScris: Lun Ian 21, 2008 1:15 pm
Dupa cum vezi in pdf , diferenta dintre 2ohm EIA si 2 ohm FTC e de 500W , eu zic ca e destul de bine :wink:
MesajScris: Lun Ian 21, 2008 1:29 pm
Adica exact ce ziceau si pe site la crown, o diferenta cam de 20%.
Pana la urma in reglementarile FTC scrie ca standardul asta e destinat echipamentelor de home-audio si nu pro.
Btw, seria max de la phonic e masurata doar pe standardul EIA, tapco vad ca a masurat pe toata gama de frecvente dar nu scrie de FTC.
http://www.tapcoworld.com/products/juic ... specs.html
MesajScris: Lun Ian 21, 2008 1:49 pm
eu cand cumpar un amplificator de putere mare il pun direct pe subbass, ce relevanta are pentru mine tampenia aia de masuratoare la 1 Khz?
pe langa asta, o astfel de masuratoare poate ascunde anumite neajunsuri ale amplificatorului (etaj final subdimensionat, sursa mica)
1 Khz e mult mai ok de obtinut decat 50Hz .
MesajScris: Lun Ian 21, 2008 3:38 pm
Localitate: Covasna
Teoretic pe sarcina rezistiva n-ar trebui sa aiba diferente semnificative intre 50Hz si 1kHz
P=Ueff*Ieff in ambele cazuri
Execut pagini web la cele mai mici preturi. Detalii pe privat.
MesajScris: Lun Ian 21, 2008 4:04 pm
rezistiva, da, dar difuzoarele sunt sarcini complexe si cam strica calculele producatorilor de amplificatoare :lol:
MesajScris: Lun Ian 21, 2008 4:06 pm
Da , dar amplificatoarele le cumperi sa dai in boxe , nu sa faci caldura pe ritmul muzicii :lol:
MesajScris: Lun Ian 21, 2008 5:53 pm
In plus standardul EIA este masurat pe un singur canal.
MesajScris: Lun Ian 21, 2008 6:17 pm
Eu vad acolo ca scrie both channels driven :roll:
 Subiectul mesajului: Intrati
MesajScris: Lun Ian 21, 2008 6:30 pm
Intrati pe link-ul principal din poze cu echipamentele noastre, v-am pus acolo filmuletz cu crown XTI 4000 Full bridge/ 4 ohm.
Ultima oară modificat de Claudiu E aka DjLeco pe Mie Mai 20, 2009 1:04 am, modificat 1 dată în total.
