Acum este Vin Iul 18, 2025 11:16 am
Reguli forum
 Subiectul mesajului: Amplificator Profesional Lab Gruppen C28:4 - Total 2800W - 4
MesajScris: Joi Dec 14, 2023 11:20 am
Vand amplificator profesional pt sonorizari, cluburi etc. Lab Gruppen C28:4 cu 4 canale, putere totala 2800W.
Amplificatorul e in stare de functionare si a fost folosit pana recent intr-un club pe partea de top-uri.
Sunet excelent, foarte puternic.
Daca sunteti interesat, contactati-ma pe mesagerie pentru un link cu un clip cu un mic test al amplificatorului.
Prefer predare personala.
Pret 6500 Ron Negociabil.
Specificatii:
Number of amplifier channels
4
Peak total output all channels driven
2800 W
Peak output voltage per channel
141 V
Max output current per channel
12 Arms
Max output power (all channels driven)
16 ohms
600 W
8 ohms
700 W
4 ohms
700 W
2 ohms
300 W
Hi-Z per CH. (all CHS driven): 70 VRMS / 100 V peak
700 W
Max output power bridged
16 ohms
1400 W
8 ohms
1200 W
4 ohms
600 W
2 ohms
Not recommended 1
Bridged per CH 140 VRMS / 200 V peak
1400 W
Performance
THD 20 Hz - 20 kHz at 1 W
0.1%
THD at 1 kHz and 1 dB below clipping
0.05%
Signal to Noise Ratio
>112 dB
Channel separation (Crosstalk) at 1 kHz
>70 dB
Frequency response (1 W into 8 ohms) + 0 / -3 dB
6.8 Hz - 34 kHz
Input impedance 20 KOHM
Common Mode Rejection (CMR)
>50 dB, 20 Hz - 20 kHz
Output impedance 100 Hz
30 MOHM
Gain, Sensitivity and Limiters
VPL, selectable per CH 2
141, 118, 100, 85, 71, 59, 50, 42 V
VPL, when bridged 2 3
282, 236, 200, 170*********** 100, 84 V
Voltage Peak Limiter mode (per CH]
Hard / Soft
Amplifier gain selectable (all channels) – rear-panel switches 3
23, 26, 29, 32, 35, 38, 41, 44 dB
Default gain
35 dB
Level adjustment (per channel)
Front-panel potentiometer, 21 position
Connectors and Buttons
Input connectors (per CH)
3-pin Phoenix, electronically balanced
Output connectors (per CH)
Barrier strip 2-pole screw terminals
Output bridge mode
A+B and/or C+D, inputs A and C are input source
Nomad-Link network
On board, 2 x RJ45 connectors IN and OUT
Intelligent fans (on/off)
Yes, depending on presence of output signal
Power
Individual switches on front panel
Cooling
Two fans, front-rear airflow, temperature controlled speed
Front-panel user interface
Common
Nomad-Link Network; Power Average Limiter (PAL)5; Power on
Per channel
Signal present / High-impedance; -10 dB and -4 dB output signal Voltage Peak Limiter (VPL); Current Peak Limiter (CPL): Very High Frequency (VHF); High temperature; Fault; Mute
Power
Operating voltage, 230 V / 115 V nominal
130-265 V / 65 -135 V 4
Minimum power-up voltage, 230 V / 115 V
171 V / 85 V
Power Average Limiter (PAL) 5
Yes
Power Factor Correction (PFC)
No
Soft-start / Inrush Current Draw
Yes / max. 5 A
Mains connector
230 V CE: 16 A, CEE7; 115 V ETL: 20 A / NEMA 5-20P; C16:4: 15A/NEMA 5-15P
Dimensions
Dimensions
W: 483 mm (19”), H: 88 mm (2 U), D: 343 mm (13.5”)
Weight
Weight
12 kg
IMG_0981.JPG [ 278.38 KiB | Vizualizat de 2667 ori ]
IMG_0982.JPG [ 267.97 KiB | Vizualizat de 2667 ori ]
IMG_0983.JPG [ 294.68 KiB | Vizualizat de 2667 ori ]
IMG_0984.JPG [ 274.63 KiB | Vizualizat de 2667 ori ]
IMG_0985.JPG [ 284.01 KiB | Vizualizat de 2667 ori ]
pret.jpg [ 168.67 KiB | Vizualizat de 2667 ori ]
