Acum este Vin Iul 18, 2025 6:22 am
Scrie un subiect nou Acest subiect este închis, nu puteţi modifica mesaje sau să scrieţi răspunsuri viitoare.  [ 20 mesaje ]  Du-te la pagina 1, 2  Următorul
 Subiectul mesajului: " QSC PLD4.5 "- amplificator 4 Canale - pareri
MesajScris: Lun Feb 13, 2017 9:13 pm
Am gasit acest amplificator QSC PLD 4.5 pe 4 ch si DSP incorporat; stie cineva sa confirme fiabilitatea si adevarul din specificatiile producatorului?
CHANNELS
4 Channels Continuous:
8 Ω: 1150 W
4 Ω: 1250 W
2 Ω: 625 W
2 Channels Continuous:
8 Ω: 2250 W
4 Ω: 2250 W
2 Ω: 2100 W
1 Channel Continuous:
8 Ω: 4200 W
4 Ω: 4200 W
2 Ω: 4250 W
1 Ω: 3700 W
1-1.0 kHz sine wave, 1% THD, 1 channel driven
DISTORTION
Typical Distortion:
8 Ω: 0.01 to 0.03%
4 Ω: 0.03 to 0.06%
Maximum Distortion:
4 to 8 Ω: 1.0%
20 Hz to 15 kHz +/- 0.2 dB
Frequency Response
20 Hz to 20 kHz + 0.2 dB
-0.7 dB (8 Ω)
Noise Characteristics
Output
Unweighted Output Unmuted: -101 dB
Weighted Output Muted: -109 dB
Gain
38.4 dB (1.2 V setting)
Damping Factor > 150
Input Impedance > 10 k, balanced or unbalanced
Maximum Input Level 3.9 V Setting: 12.28 V (+24 dBu)
1.2 V Setting: 3.88 V (+14 dBu)
Controls and Indicators
Front:
Power
Channel mute buttons
Channel select buttons
Channel input signal and clip LED indicators
Channel output and limit LED meters
Home, enter, exit, gain navigation buttons
Control knob
Rear:
AC power disconnect
Input Connectors Female XLR
Output Connectors NL4
Amplifier
Amplifier and load protection:
Short circuit, open circuit, thermal, RF protection. On / Off muting, DC fault shutdown, active inrush limiting, input current limiting
AC Power
Input: Universal power supply 100 to 240 VAC, 50 to 60 Hz
Agency Approval UL, CE, RoHS / WEEE compliant, FCC Class A (conducted and radiated emissions)
Dimensions (H x W x D) 3.50 x 19.00 x 16.00" (8.89 x 48.26 x 40.64 cm)
Weight 22.00 lb (9.98 kg)
Pret: Aprox:10000-12000 RON
 Subiectul mesajului: Re: " QSC PLD4.5 "- amplificator 4 Canale - pareri
MesajScris: Lun Feb 13, 2017 11:46 pm
5KW RMS dintr-un conector IEC de 10A.... pe 110V :roll:
trage 1100W de la retea si debiteaza 5000
nu stiu ce fumeaza astia.
Inteleg ca e eficient dar parca nici chiar asa...
asa ca si gandire nu mi se pare neaparat un amplificator rau dar partea cu puterea ma cam enerveaza.
Cred ca se potriveste la fix cu difuzoarele Eminence care au specificatiile la putere la fel de umflate.
Parca e 2000 din nou si avem casetofoane cu 50000W PMPO :?
fucking marketing!
MesajScris: Mar Feb 14, 2017 5:56 pm
Acelasi lucru pot sa spun si eu...
MesajScris: Mie Feb 15, 2017 12:19 am
dar uite ce ecran color are :P
Oare prinde posturi straine?
MesajScris: Mie Feb 15, 2017 2:12 pm
erau la vanzare cateva in stare foarte buna si la super pret prin olanda
stau si ma intreb... oare de bune ce-s le vand aia? :?
MesajScris: Mie Feb 15, 2017 3:20 pm
tu cam ce crezi?
:twisted:
MesajScris: Joi Feb 16, 2017 2:43 am
oare pe display-ul ala frumos putem juca snake? :mrgreen:
MesajScris: Joi Feb 16, 2017 3:31 pm
daca merge Carmageddon, vreau si eu unul :twisted:
MesajScris: Vin Feb 17, 2017 10:58 pm
Totusi sa nu fim rai, amplificatorul are un design dragut, dar puterea nu are cum sa fie cea specificata, poate doar burst de citeva milisecunde cit se descarca capacitorii apoi se limiteaza la asa zisul RMS pe care il poate oferi.
Eu cam asa banuiesc ca se comporta...
MesajScris: Vin Mar 03, 2017 2:37 pm
Localitate: Buzau
Aici vin si eu cu o intrebare. Intra-adevar acest amplificator nu are cum sa debiteze puterea specificata.
INTREBARE : Powersoft K20 cum debiteaza o putere de 2 x 9000 W atata timp cat din retea trage 230v ?
Inteleg ca este powersoft dar.......
MesajScris: Vin Mar 03, 2017 3:24 pm
Curentul absorbit este important nu tensiunea.
Amplificatoarele gen Powersoft K20 se bazeaza pe langa sursa de alimentare pe un rezervor de energie sub forma unui banc de condensatori intre sursa si etajul final. Sursa alimenteaza acel banc de condensatori in mod continuu cu o putere constanta iar etajul final extrage energie din el.
Smecheria consta in faptul ca semnalul muzical nu are duty cycle de 100%. In realitate, este undeva pe la 30-60% in functie de genul muzical reprodus.
Folosind metoda asta putem debita puterile specificate absorbind in mod constant de la priza cam 50-70% din valoare puterii debitate la iesire pe programul muzical.
un K20 trage de la retea aproape 60 de A cand functioneaza la 2 ohmi/canal la putere maxima.
Asta ar fi cam 13.8KW absorbiti.
Acest amplificator are o eficienta masurata de aproximativ 85%, ceea ce inseamna ca pana la 15% din puterea absorbita de la retea este cedata sub forma de caldura.
Un alt lucru foarte important la acest gen de amplificatoare este PFC-ul. Acesta pe langa faptul ca protejeaza sectiunea de alimentare (conectica), ajuta si la controlarea curentului absorbit de la retea, disparand spike-urile care se pot observa in designurile ieftine gen Behringer Inuke, care are varfuri de consum de ordinul microsecundelor de sute de A pentru ca sursele nu sunt construite corect. Aceste varfuri afecteaza atat liniile de alimentare , cat si celelalte echipamente conectate la aceeasi retea electrica.
MesajScris: Vin Mar 03, 2017 3:30 pm
Localitate: Buzau
In teorie ai dreptate 100%. Nu te contrazic dar totusi sunt foarte multi care nu cred 100% in acele specificatii de catalog.
Sincer in acei foarte multi care nu cred ma aflu si eu.
Nu zic ca nu ar fi un amplificator foarte bun dar mai stiam ca modelul K10 il poti transforma intr-un K20 folosind un card.
Pai atunci nu e mai bine sa luam k10 si sa il transformam in K20 diferenta de pret fiind consistenta?
Si sa fiun ONTOPIC eu zic ca si acest qsc este o scula destul de buna dat fiind faptul ca cei de la qsc au majoritatea produselor foarte bune.
MesajScris: Vin Mar 03, 2017 4:06 pm
1. Parerea ta este irelevanta. Nu ai cunostintele necesare sa intelegi cum functioneaza acest amplificator. E ca si cazul celor care sunt absolut convinsi ca pamantul este plat, de exemplu. https://theflatearthsociety.org/home/ Oricat de mult ar fi ei convinsi ca au dreptate, pamantul va fi tot rotund :))
2. Acest amplificator nu este proiectat pentru DJ mobili si nici nu are ca si destinatie piata pe care activezi tu. Aceste amplificatoare sunt destinate marilor firme de sunet ce au bugete de milioane de euro. Un mare client Powersoft este Britania ROW Productions, care a cumparat dintr-un foc acum cativa ani amplificatoare totalizand peste 1 Milion de W de la Powersoft.
http://www.britanniarow.com/
3. Amplificatoarele din seria K pot fi trecute la pragul superior cu un STEP-up Card pentru ca mai multe modele sunt in realitate exact acelasi amplificator , dar modelele sunt limitate din soft.
In realitate in seria K exista doar 3 amplificatoare produse in realitate. Diferentele dintre ele sunt doar in software. Postez mai jos platformele si posibilitatile de upgrade:
- upgrade-urile posibile sunt:
Platforma 1 - K2 -> K3
Platforma 2 - K6 -> K8 -K10
Platforma 3 - este K20 . Acest model nu poate fi upgradat pentru ca este o platforma de sine statatoare.
QSC-ul ala nu este o scula foarte buna. Este un amplificator gandit sa dea foarte bine in specificatii, care sa mearga bine cu boxele actuale care au puterile declarate mincinos.
MesajScris: Vin Noi 24, 2017 8:45 pm
Nu inteleg de ce QSC are puterile declarate mincinos, adica in urma carui fapt? Powersoft are banc de condensatori pe post de rezerva, OK.
QSC s-a axat pe alt principiu, mai simplist si a presupus ca nu va incerca nimeni sa traga 5KW din el. El e capabil sa absoarba 22A din reteaua de 230V, dar eu nu stiu daca se aprinde ca o torta sau pur si simplu se stinge.
https://www.qsc.com/resource-files/productresources/amp/pld/q_amp_pld_currentdraw-230vac.pdf
Din manualul lor (al mai mare) puterea maxima continua este data doar pe un singur canal, restul fara sarcina (a se citi nota de subsol 1 - 1.0 kHz sine wave, 1% THD, 1 channel driven)
Cand sunt toate 4 cu sarcina, puterea este Peak sau Burst, acelasi lucru.
O comparatie mai decenta este cu Powersoft X4 sau ce X o mai fi. Aici un review despre ele (Powersoft) si cum e cu puterile absorbite si cele debitate.
http://www.powersoft-audio.com/en/docman/1012-x-seriestestrevieweng/file
The maximum continuous performance of the X4 for a 1 kHz sinusoidal signal with simultaneous load of all four channels lays – depending on the load impedance – at 580 to 689 W.
El avand declarat 1600 @ 8 Ohmi si 3200 @ 4 Ohmi, pe canal.
PS. N-am nicio treaba cu QSC sau Powersoft. Amandoi fac scule misto.
MesajScris: Vin Noi 24, 2017 9:56 pm
Uita-te la conectorii de retea si gandeste-te ca amplificatorul este construit sa mearga pe 110V folosind acelasi conector.
Ai zis ca nimeni nu va incerca sa traga 5 kw. Te contrazic: TOTI vor incerca sa traga 5 Kw sau chiar mai mult din el!
Abordarea QSC este de tip "low cost" , la fel ca si Behri ger seria Inuke care este o insulta la adresa amplificatoarelor profesionale.
