Acum este Sâm Iun 07, 2025 10:15 am
Scrie un subiect nou Răspunde la subiect  [ 42 mesaje ]  Du-te la pagina 1, 2, 3  Următorul
 Subiectul mesajului: fulrange cu win15s + pad 52 + ph220
MesajScris: Vin Mai 11, 2007 9:45 pm
Localitate: onesti
asta este una din ultimele achizitii ale mele . mai vin inca 2
1. http://tinypic.com/view.php?pic=63crdit
2. http://tinypic.com/view.php?pic=4u9wcad
3. http://tinypic.com/view.php?pic=6cww1t3
4. http://tinypic.com/view.php?pic=4r9mko1
5. http://tinypic.com/view.php?pic=5z3vmyp
6. http://tinypic.com/view.php?pic=4y8ntck
7. http://tinypic.com/view.php?pic=6bdgnde
8. http://tinypic.com/view.php?pic=61loa3o
9. http://tinypic.com/view.php?pic=4ygztp5
10. http://tinypic.com/view.php?pic=4p9yftd
11. http://tinypic.com/view.php?pic=688dv7r
12. http://tinypic.com/view.php?pic=663iihi
13. http://tinypic.com/view.php?pic=5236vya
14. http://tinypic.com/view.php?pic=62epdg5
goarna + filtru
http://tinypic.com/view.php?pic=639q2pf
http://tinypic.com/view.php?pic=5y1acn5
o poza cu win-ul in mana
http://tinypic.com/view.php?pic=6bitzwk
icinta 100 l , acordat la 50 hz , constructie pal puternic ramforsat , filtru si pe bas si pe inalta made by shambala
astept pareri
MesajScris: Vin Mai 11, 2007 10:03 pm
ti-au iesit faine :wink: felicitari !!!
Cum suna combinatia wn15s+pad52 cu bph?
De abia astept maine sau luni imi vin si mie wn15r si ne apucam de treaba (eu cu userul webber) ... c18 650 el deja a venit impreuna cu padurile :D ... sper in 2 sapt sa fie gata:D
MesajScris: Vin Mai 11, 2007 10:05 pm
nu pui pozele cu [img] te rog. Sunt pe dial up acuma si mai bine las pagina sa se incarcedecat sa tot stau pe o poza :wink: , daca vrei bineinteles :roll:
MesajScris: Vin Mai 11, 2007 10:18 pm
Localitate: onesti
pitbull_dog
combinatia suna bine , amandoua au spl mare + ca mai vin inca 2 is gata in 3 zile. abia astept sa le testez
adi_rcf
intra pe mess sa-ti trimit poze
MesajScris: Vin Mai 11, 2007 10:32 pm
sunt pe dial up, tot aia e. :wink:
MesajScris: Vin Mai 11, 2007 10:36 pm
Cu ce le-ai vopsit? :oops:
Super treaba 8)
MesajScris: Vin Mai 11, 2007 10:51 pm
Localitate: onesti
Sandu_Alex_999 scrie:
Super treaba 8)
le-am vopsit cu isonorizant auto 2 straturi dupa care vopsea rezistenta
MesajScris: Sâm Mai 12, 2007 10:08 am
Nu ma pricep la vopsire si nici vopsele dar vreau sa intreb daca insonorizantul auto nu e tot una cu vechiul autovapant? vopseaua aceea groasa care se folosea al izolatia masinii pe dedesupt.
SPER sa nu zic o prostie..dar ai folosit lemn de brad la ramforsarea dintre placile frontala si cea din spate :? Lemnul acela taiat pe fibra probabil e mai tare decat palul dar la lungimea aia eu pot sa garantez ca se va contracta sau se va extinde cativa milimetrii...in functie de umezeala din aer.
sa fii atent ..in caz ca iti va trage placa din fatza inspre inapoi( e punctul mai slab) sa nu cumva sa fie o mica curbura acolo si sa sufle aerul pe langa difuzor sau hornul de la driver.
PS: arata super bine boxele felicitari singura obiectie legata de design ar fii ca puteai face putin altfel cu porturile alea..doar o chestie de aspect..
MesajScris: Sâm Mai 12, 2007 10:44 am
Localitate: onesti
noobsound scrie:
la porturi nu conteaza ca o sa vina tabla perforata si burete fonotransparent
in legatura cu acea placa nu stiu ce sa zic ... placa e prinsa in 2 holtzsuruburi la fiecare capat si data cu aracet la imbinare
MesajScris: Mie Mai 16, 2007 9:26 pm
Localitate: oradea
tu ai vrut dispersie mai larga pe verticala? 8)
MesajScris: Mie Mai 16, 2007 10:02 pm
Localitate: onesti
salut
cand am facut pozele avea dispersia mai mare pe verticala acuma ii invers
Cum ti se pare pad52 ? Daca tii corectorul de ton pe driver la 0 te multumesc inaltele ?
MesajScris: Mie Mai 16, 2007 11:00 pm
Localitate: onesti
pufuletz scrie:
inca nu stiu....maine aflu...maine vin 3 pad52 ....dar in schimb am auzit varianta eminence psd-2002 ( parca asa se cheama ) si suna criminal
MesajScris: Sâm Mai 26, 2007 9:47 pm
Nu fiti dusi in eroare de pretzul mai mic al PAD52.. suna super bine..fata de un pht e o diferenta enorma..
@pufuletz nu numai ca il vor multumii dar vor si trebuii atenuate 5 DB
@crexy spunene te rog cum ai vopsit mai detaliat si cu ce anume. multumesc anticipat
MesajScris: Lun Mai 28, 2007 7:13 pm
Localitate: onesti
salut
pai prima data slefueste bine incinta dupa care dai cu kit astefel incat sa fie suprafata perfect plana , dupa aia dai cu insonorizant ( firma mai buna) cu pistol special si lasi sa se intareasca , dupa dai cu 2 straturi de vopsea neagra mata mai rezistenta (nemteasca) cu pensula , in cazul meu , si vopseaua o lasi mai groasa , in poze nu prea se vede dar in realitate zici ca-i facuta de fabrica
spor la treaba
