Mai jos va prezentam poze cu difuzorul Beyma 15MI100.
http://www.poweraudio.ro/difuzoare_prof ... ?filter=18TECHNICAL SPECIFICATIONS
Nominal diameter 380 mm 15 in
Nominal impedance 8 ohm
Minimum impedance 6.6 ohm
Power capacity 450 W AES
Program power 900 W
Sensitivity 100 dB 1 W @ 1 m @ ZN
Frequency range 40-5000 Hz
Recommended enclosure volume -
Voice coil diameter 77 mm 3 in
BL factor 19.2 N/A
Moving mass 0.077 kg
Winding length 13.7 mm
Air gap height 10 mm
Xdamage pp 24 mm
THIELE SMALL PARAMETERS
Fs 37 Hz
Re 6.2 ohm
Qms 6.38
Qes 0.3
Qts 0.29
Vas 264 l
Cms 240 µm / N
Rms 2.8 kg / s
Efficiency % 4.3
Sd 0.088 m²
Xmax 4.5 mm
Vd 396 cm³
Le @1 kHz 1 mH
CONSTRUCTIVE DETAILS
Net weight 7.8 kg 17.2 lb
Total weight 8.6 kg 18.9 lb
Magnet Ferrite
Fişiere ataşate: |
IMG_3097.JPG [ 256 KiB | Vizualizat de 3559 ori ]
IMG_3098.JPG [ 197.36 KiB | Vizualizat de 3559 ori ]
IMG_3099.JPG [ 203.58 KiB | Vizualizat de 3559 ori ]
IMG_3100.JPG [ 138.79 KiB | Vizualizat de 3559 ori ]
IMG_3101.JPG [ 266.66 KiB | Vizualizat de 3559 ori ]
IMG_3102.JPG [ 178.9 KiB | Vizualizat de 3559 ori ]
IMG_3103.JPG [ 211.53 KiB | Vizualizat de 3559 ori ]
IMG_3104.JPG [ 193.81 KiB | Vizualizat de 3559 ori ]
IMG_3105.JPG [ 218.86 KiB | Vizualizat de 3559 ori ]
