Acum este Sâm Iul 05, 2025 4:14 pm
 Subiectul mesajului: Beyma 6MI100
MesajScris: Joi Oct 15, 2015 8:43 am
Mai jos va prezentam poze cu difuzorul Beyma 6MI100.
Acest difuzor profesional poate fi achizitionat din magazinul nostru on-line urmand acest link:
http://www.poweraudio.ro/difuzoare_prof ... ?filter=13
TECHNICAL SPECIFICATIONS
Nominal diameter 165 mm 6.5 in
Nominal impedance 8 ohm
Minimum impedance 6.8 ohm
Power capacity 250 W AES
Program power 500 W
Sensitivity 94 dB @ 1 W @ ZN
Frequency range 100-8000 Hz
Voice coil diameter 51.7 mm 2 in
BL factor 10.8 N/A
Moving mass 0.014 kg
Winding length 9.2 mm
Air gap height 7 mm
THIELE SMALL PARAMETERS
Fs 128 Hz
Re 6 ohm
Qms 8.6
Qes 0.55
Qts 0.51
Vas 3.07 l
Cms 119 µm / N
Rms 1.2 kg / s
Efficiency % 1.2
Sd 0.014 m²
Xmax 3 mm
Vd 42 cm³
Le @1 kHz 0.2 mH
CONSTRUCTIVE DETAILS
Net weight 2.2 kg 4.84 lb
Total weight 2.3 kg 5.06 lb
Magnet Ferrite
IMG_1928.JPG [ 248.83 KiB | Vizualizat de 3247 ori ]
IMG_1929.JPG [ 203.99 KiB | Vizualizat de 3247 ori ]
IMG_1930.JPG [ 212.59 KiB | Vizualizat de 3247 ori ]
IMG_1931.JPG [ 245.28 KiB | Vizualizat de 3247 ori ]
IMG_1932.JPG [ 196.49 KiB | Vizualizat de 3247 ori ]
IMG_1933.JPG [ 205.21 KiB | Vizualizat de 3247 ori ]
IMG_1934.JPG [ 201.33 KiB | Vizualizat de 3247 ori ]
