Acum este Mie Iun 04, 2025 12:05 pm
 Subiectul mesajului: B&C DE250
MesajScris: Mie Oct 14, 2015 2:51 pm
Mai jos aveti poze cu driverul B&C DE250.
Acest driver profesional poate fi achizitionat din magazinul nostru on-line urmand acest link:
http://www.poweraudio.ro/difuzoare_prof ... r=26,25,23
DE250
120 W continuous program power capacity
1' horn throat diameter
44 mm (1.7 in) aluminium voice coil
Polyimide diaphragm
1000 - 18000 Hz response
108.5 dB sensitivity
Specifications *
Throat diameter
25 mm (1.0 in)
Nominal impedance
8 Ω
Minimum impedance
7.8 Ω
Nominal power handling *
60 W
Continuous power handling *
120 W
Sensitivity (1W/1m) *
108.5 dB
Frequency range
1 - 18 kHz
Recommended crossover *
1.6 kHz
Voice coil diameter
44 mm (1.7 in)
Winding material
Aluminium
Inductance
0.11 mH
Diaphragm material
Polyimide
Flux density
1.85 T
Magnet material
Ferrite
Mounting And Shipping Info
Two M6 holes 180° on 76 mm (3 in) diameter
Three M6 holes 120° on 57 mm (2.2 in) diameter
Overall diameter
120 mm (4.7 in)
Depth
62 mm (2.4 in)
Net weight
2.1 kg (4.6 lb)
Shipping units
8
Shipping weight
17.5 kg (38.5 lb)
Shipping box
260x260x190 mm (10.2x10.2x7.5 in)
Replacement Diaphragm
MMDDE2508
IMG_2963.JPG [ 220.88 KiB | Vizualizat de 3541 ori ]
IMG_2964.JPG [ 200.3 KiB | Vizualizat de 3541 ori ]
IMG_2965.JPG [ 248.13 KiB | Vizualizat de 3541 ori ]
IMG_2966.JPG [ 257.84 KiB | Vizualizat de 3541 ori ]
IMG_2967.JPG [ 236.17 KiB | Vizualizat de 3541 ori ]
