Acum este Dum Iul 13, 2025 9:05 pm
Scrie un subiect nou Răspunde la subiect  [ 44 mesaje ]  Du-te la pagina 1, 2, 3  Următorul
 Subiectul mesajului: subwoofer pd 2450
MesajScris: Mie Feb 04, 2015 7:19 pm
a facut cineva un subwoofer cu pd2450....?
aveti vreo idee de incinta pt home?
 Subiectul mesajului: Re: Studiu de caz : subwoofer pd 2450
MesajScris: Vin Mar 13, 2015 9:35 am
Oare care este cea mai potrivita alegere de proiect pentru o incinta audio care sa puna in valoare un asemenea difuzor ?
La o prima cautare pe net , am gasit un site japonez : http://kiirojbl.web.fc2.com/audio/audio88.htm
Acolo se specifica cateva detalii , unele absolut firesti pentru o solutie BR ( 320litri intern , cu un acord la 30 Hz ) :
" PD.2450 (3) and is soon playing with never change, mono 6 way and phase time of demolition is imminent, we have got a learned or rather.
It was found that it is possible to greatly adjust the bass texture of the from the addition of mid bass.
The bass part, 25cm4 shot of mid-based, 38cm4 shots of woofer of the V-shaped baffle, and has been constructed from 3-way that 46cm1 shot of subwoofer of pseudo V-shaped baffle.
For example, if you raise the level of the subwoofer, feel that bounced no longer raised the level of the woofer section will retreat.
Therefore, increasing the level of woofer part by lowering the level of the subwoofer, the But I feel that bounded if there is a V-shaped baffle seems punch comes out, this time it will not match the texture of 2392 + 2490H.
Therefore, adjusting the cross of the mid-base and woofer part.
It's 120Hz is a strong character of the woofer section, but the honest sound of mid bass becomes the dominant Lowering up to 100Hz.
Mid base for us to bridging the gap between the texture of the woofer section and the 2392 + 2490H.
I wonder if there is a need to 3 split the 300Hz or less?
When Initially I thought quite doubt, it is now I think not bad by now.
Taking advantage of the meager know-how gained through these adjustments, and I tried to re-adjust the yellow horn system.
Clear controls, such as mono 6 way is hard, but still the relationship between the change of equalizing and cross of adjustment and sound've got to understand than before.
For boost of the lowest band was excessive, bass atmosphere of has changed significantly when a little lift the to suppress 50Hz ~ 80Hz here.
On the other hand, it does not start unless made ​​the ... box and say what happened to PD.2450.
However, I was lost in the volume of this box.
And I had planned a 500L ~ 600L initially, but when I checked on the design software of various box 300L position is displayed as appropriate volume.
Recommended volume of PD.2450 has become a 130L ~ 400L, but numerical value of this 300L is not visible to the so abnormal, but still ...
I want to and because it is for the subwoofer of 61cm to more big box Furthermore, unit is 36kg and heavy for, you invited anxiety for attachment to baffle plate.
Is it can be matched well the screw holes with the screw holes on the unit of the baffle plate when installing the unit, then, do not than when are mounting a long period of time no longer removing the unit and the baffle plate and is sticking unit.
These things also harassment.
So, this time it was to be linked with the bolt in order to be able to attach and detach the back plate and the baffle plate.
Attach the unit to the baffle plate, then, work be attached to the baffle plate each box of whether not easy.
In addition, even if accidentally baffle plate and the unit is stuck, it intends Yasukaro deal as long as it can be removed from the baffle plate per box.
Then, remove the back plate if you feel like increasing the box of volume, so you can easily increase the volume to be attached the extended portion of the newly produced the side plate.
Eventually, it was decided to design an effective volume 300L in the goal. Use the 24mm thickness China plywood.
Inside dimension volume is 358L (inside dimension 852W × 702H × 600Dmm, external dimensions 900 × 750 × 663mm).
Reinforcements, ducts, unit, and calculates the volume reduced by a small amount of the sound absorbing material about 38L.
Thus the effective volume 320L. About duct tuning off the 30Hz little.
Duct openings 200 × 130mm, is two is duct length 339mm.
Because the dimensions of the mounting holes on the unit has not been shown in the brochure, where it was a hole with a diameter of 568mm, this is released.
Unit does not enter at the little later.
You got Kotonaki by overlapping 15mm China plywood of a hole of 578mm because there is no way.
For this reason, the thickness of the baffle plate has become the 39mm.
Although other also manufacture there are here and there mistake was repeated seesawing, I was able to somehow complete. "
Pentru a intelege mai bine acest proiect , foarte deosebit fata de proiectele clasice cu difuzoare de dimensini normale ( pana in 18" ) va prezint un proiect asemanator de la o firma de renume ( P-Audio ) proiect diferit pentru ca este destinat unui difuzor de doar 21" , si care probabil a stat la baza celui japonez descris mai sus : http://www.paudiothailand.com/pdf/Syste ... Y-121S.pdf . remarcati cata importanta s-a dat structurii antirezonante a incintei , pentru a nu se rupe in bucati :) .
Nu este de joaca cu greutati si volume mari , cu difuzoare care genereaza presiuni incredibile ... acest difuzor este din categoria difuzoarelor din prima liga si cu siguranta joaca doar in finala mare !
882.jpg [ 264.39 KiB | Vizualizat de 9000 ori ]
881.jpg [ 225.38 KiB | Vizualizat de 9000 ori ]
 Subiectul mesajului: Re: subwoofer pd 2450
MesajScris: Vin Mar 13, 2015 9:47 am
La o a doua cautare pe net am gasit inca un proiect , ceva mai complicat dar creditat de cattre Turbosound cu performante superioare ( ? ) din punct de vedere al SPL-ului si al functionarii tranzitorii fata de proiectul anterior : http://fr.audiofanzine.com/hp-cone/prec ... sw124.html
image03.jpg [ 88.06 KiB | Vizualizat de 8996 ori ]
image02.jpg [ 139.95 KiB | Vizualizat de 8996 ori ]
image01.jpg [ 104.27 KiB | Vizualizat de 8996 ori ]
MesajScris: Vin Mar 13, 2015 10:03 am
Dupa ce am analizat cele doua proiecte , adica cel japonez si cel de la Turbosound am intrat la idei si mi-am pus cateva intrebari intrebatoare :
- oare de ce unii au ales BR iar ceilalti Horn ?
- ce amanunte se ascund in spatele listei cu parametri electromecanici ai difuzorului ?
- care este solutia optima pentru sonorizare de interior ( netransportabila ) sau de exterior ( touring )
- etc .
Ce parere aveti ?
MesajScris: Vin Mar 13, 2015 11:00 am
Victor am o intrebare: Incinta Japonezului nu este acordata prea jos? (30hz). Pe mine ma intereseaza pentru sonorizari, nu pentru casa.Daca da , cat trebuie scurtate porturile? Pentru ca simuland cu Winisd iti da o lungime, simuland cu winisd pro iti da alta lungime.
-Iar adancimea se poate modifica?, repectand litrajul. Ma intereseaza adancimea mai mica si sa cresc putin inaltimea.
--Inaltimea=1019,9mm, latimea=702mm , adancimea=500mm (porturile 20 x 13 x 35,46cm (winisd) 30hz, iar acordata la 40hz 20 x 13 x 14,66 cm ) Respectand litrajul gol al japonezului de 358l
-Multumesc!
Ultima oară modificat de Vasile Nicolaie pe Vin Mar 13, 2015 11:38 am, modificat 1 dată în total.
MesajScris: Vin Mar 13, 2015 11:37 am
Absolut deloc .
Eu am in vedere o altfel de incinta , cu acord la 27 Hz pentru ca difuzorul permite , are un BL monstruos de mare , dar va fi necesar un filtru subsonic fix la 27 Hz .
In opinia mea , intentia producatorului a fost ca acest difuzor sa fie dedicat redarii spectrului de frecvente dintre 25Hz -6 dB pana la 70 Hz -6 dB , conform parametrului MMS , care este foarte mare .
Incinta pe care o propun va fi un hibrid intre back horn loaded si linie de transmisie , acordata astfel ca lambda/8 sa fie la frecventa de 27 Hz .
Orice varianta BR o exclud din start , am motive serioase .
In acest caz , BR-ul ar fi un compromis pentru sonorizari , pentru aplicatii casnice se accepta orice cazan urlator ...
MesajScris: Vin Mar 13, 2015 11:39 am
-Asteptam cu interes ! Multumesc!
MesajScris: Vin Mar 13, 2015 9:14 pm
-Victor, ce nu iti place la bass reflex ? De ce excluzi din start aceasta varianta? Ce este in neregula cu Bassul reflex?
-Pentru sonorizari medii in interior si la fel in exterior nu e bun BR?
Ultima oară modificat de Vasile Nicolaie pe Sâm Mar 14, 2015 12:19 pm, modificat de 2 ori în total.
MesajScris: Sâm Mar 14, 2015 4:01 am
Vasile Nicolaie scrie:
-Multumesc!
Simulare WinIsd Pro! Care acordaj este mai ok pentru sonorizari? Ma puteti lumina. Multumesc!
-358l acordata 30hz. 1000w distanta:10m Spl: 30hz - 123,3 db
40hz - 125 db
50hz - 125,6 db
90hz - 127,5 db
-358l acordata la 40hz. 1000w distana:10m SPL: 30hz - 118,5db
40hz - 127,7 db
50hz - 128,9db
90hz - 128,4 db
-Ce sa inteleg din asta? Pentru sonorizat e mai bine sa fie acordata la 40hz? Care este lungimea porturilor? Din cate am citit Winisd , nu calculeaza bine lungimea porturilor. Porturile sunt cele din proiectul Japonezului 2 per cutie. Masuri interioare: 20 x 13cm x 33,9cm lungime asta la 30hz......la 40hz WinIsd mi-a dat lungimea portului de 138 mm
-In asteptarea proiectului lui Victor , intreb acest lucru cu acordajul la Br 358l , ca o varianta de rezerva in caz ca va fi complicat proiectul lui !
-Care acordaj este mai ok , la proiectul Japonezului?
MesajScris: Sâm Mar 14, 2015 7:25 pm
Mda , ai cazut deja in eroarea incepatorilor ... asta nu este un full range , un subwoofer se acorda altfel .
40 Hz se aud intr-un anume fel dintr-un full range si altfel dintr-un subwoofer adevarat .
De aia eu am sarit din calcule incinta tip BR , chiar daca are avantaje gen greutate , volum , constructie simpla .
Chiar ii crezi definitiv tampiti pe cei de la Turbosound ?
Nu ti se pare ca se ascunde " ceva " in lista de parametri electromecanici ai acestui difuzor ?
Eu consider ca se justifica sa realizezi direct proiectul celor de Turbosound sau astepti rezultatele estimarilor mele .
Oricum esti liber sa procedezi cum doresti , tu esti propietarul de drept al difuzoarelor si nu ai nicio obligatie fata de nimeni si nimeni nu are nicio obligatie fata de tine .
Nu pierde vremea , studiaza varianta Turbosound .
Mai exista si altii pe lumea asta : http://dashboard.blaakmeer.com/uploads/ ... asheet.pdf , trebuie doar sa cauti suficient si sa te inarmezi cu foarte multa rabdare !
MesajScris: Sâm Mar 14, 2015 8:21 pm
aceeasi recomandare i-am dat-o si eu
PD2450 a aparut ca si difuzor OEM care dota TSW124, nu a fost produs intamplator.
MesajScris: Sâm Mar 14, 2015 8:57 pm
-Victor clar ca astept! Eu sunt incepator si imi place sa invat! Clar ca cad, si voi cadea in multe capcane , pentru ca e firesc la inceput sa se intample acest lucru. De aceea si cer ajutor oamenilor cu experienta! Si va multumesc tuturor pentru acest lucru! Cat despre TSW124, eu nu pot construi aceasta incinta pentru ca nu stiu! Daca exista cineva sa poata construi aceasta incinta sa imi spuna un pret pe privat!
-Multumesc!
MesajScris: Mie Mar 18, 2015 1:16 pm
Se pare ca m-am impotmolit in acest proiect propriu si nu gasesc iesirea ... cred ca renunt , nu am timp de pierdut .
Pentru moment va ramane valabila doar varianta Turbosound .
MesajScris: Mie Mar 18, 2015 5:10 pm
-Multumesc! Cat de curand voi incepe contructia a 2 incinte dupa un proiect dat de Dan ( DNA). O sa revin cu poze si pareri!
MesajScris: Joi Mar 19, 2015 5:27 am
Ce fel de proiect a propus Dan ?
Se poate populariza pe forum sau este un proiect propriu , nedestinat publicului ?
Ce performante va avea acest proiect ?
