Acum este Mie Iul 16, 2025 2:50 am
 Subiectul mesajului: parametrii e12-100s
MesajScris: Mar Dec 20, 2005 6:46 am
Localitate: oradea
astias parametrii difului pe care il importati?
Sensitivity (1 w/1 m) 97 dB
Magnet Weight 1.16 Kg
Resonant Frequency Fs 41 Hz
Impedance Re 5.6 ohm
Electromagnetic Q Qes 0.37
Mechanical Q Qms 5.82
Total Q Qts 0.35
Compliance Equivalent Volume VAS 138.86 Litr
Surface Area of Cone Sd 510 cm2
Reference Efficiency ηO 2.48 %
Voice Coil Overhang Xmax 2 mm
Diaphragm Mass inc Airload Mms 39.96 Gram
Bl Product BL 12.3 TM
Coil Inductance Le 0.83 mH
pe pdf ul de pe poweraudio nu sunt date numai vreo 4 parametrii, iar pe pacoustic nu este modelul asta :evil:
MesajScris: Mar Dec 20, 2005 4:02 pm
Power Rating : 100~200 Watts
Nominal Chassis Diameter : 305 mm (12 in)
Nominal Impedance : 4~8 ohm
Sensitivity (1w/1m) : 97 dB
Magnet Weight : 1.16 Kg (41.05 oz)
Resonant Frequency Fs : 41 Hz
Impedance Re : 5.6 ohm
Electromagnetic Q Qes : 0.37
Mechanical Q Qms : 5.82
Total Q Qts : 0.35
Compliance Equivalent Volume VAS : 138.86 Litr
Surface Area of Cone Sd : 510 cm
Reference Efficiency ?o : 2.48 %
Voice Coil Overhang Xmax : 2 mm
Diaphragm Mass inc Airload Mms :
39.96 Gram
Bl Product BL : 12.3 TM
Coil Inductance Le : 0.83 mH
MesajScris: Mie Dec 21, 2005 6:29 am
Localitate: oradea
ms
vad cas aceeasi
io de aici iam luat http://www.bekar-m.ru/paudio/e12100s.htm
