Acum este Mie Iul 16, 2025 12:42 am
 Subiectul mesajului: Recomandare controler DMX
MesajScris: Mar Apr 03, 2012 7:28 pm
Ce controler DMX ar fi mai bun pana in 500ron? Mentionez ca momentan nu am nici o lumina sau efect, vreau doar sa ma apuc de evenimente si nu stiu ce ar fi mai indicat ca si controler DMX(de asemenea nu am utilizat niciunu pana acum)
Multumesc
full-range :2xC12-300mb+comp50+PH-2420
subwoofer: 2XLW1503
top: 2x12D01
Mixer: soudking AS602A
Procesor: CX3400
DMX: BT SM061
Amplificator: 2xFET400
4xFET400
Microfon: YAMAHA DM500
 Subiectul mesajului: Re: Recomandare controler DMX
MesajScris: Mie Apr 04, 2012 10:11 am
acest model il avem in stoc si poate fi livrat de pe o zi pe alta
192 channel DMX controller
12 Scanners of 16 channels each
30 Banks of 8 programmable scenes
6 Programmable chases of 240 scenes
8 Sliders for manual control of channels
Assignable joystick for ease of channels
File Dump allows data to be sent or received between two units
Auto mode program controlled by speed and fade time silders
Fade time/Assign fade time
Reverside DMX channels allows fixture to react in opposition to others in a chase
8 CHANNEL or 16 CHANNEL mode
Fine adjustment for joystick pan and tilt
Blackout master button
Manual Override button allows you to grab any fixture on the fly
Built in microphone for music triggering
MIDI control over banks,chase and blackout
DMX Polarity selector
Power failure memory
Dimensions:483x132x80mm
Weight:2.5kg
costa 450 de lei cu TVA inclus si poate controla cam tot ce poti avea tu nevoie
noi il folosim in instalatii de lumini din cluburi si discoteci, insa merge si pentru Dj mobili pentru ca e relativ compact.
