...din cate am vazut,este aceeasi eroare ca si la tine. Ca sa rezolvi problema trebuie sa descarci ultima versiune de driver pentru win 7 (userul de pe youtube a mentionat acest lucru in descrierea clipului postat)
Citez:
"I get this error when trying to install the driver.
Update 5/8/2012: Problem was fixed by installing new updated firmware to the controller."
Pe site la Numark
http://www.numark.com/support/downloads/idj3Descarci si instalezi versiunea asta
MixVibes -- 32 Bit Windows Drivers [v2.9.11] 1.01 MB.zipCand mi-ai aratat prima oara eroare data la instalare, ai luat un driver din 2010
Un alt mod de update la driver este:"""""""""""""""""""""""""
Jose Martinez 3 months ago
I got it fixed, the problem was the firmware I just had to upgrade it. While I still get the 0x0005 problem while I Install Virtual DJ now recognizes the device and works perfectly.
comment good solution!
Philip Huynh 1 month ago
How did you upgrade the firmware?!
good solution!
J Sandeen (Technical Representative) 1 month ago
*First make sure the computer sees the controller through your device manager before running the update. If you have connection issues the update will not successfully complete.
You will need the firmware update file.
UPDATE DRIVER - verifica instructiunile date in PDF-ul din arhivaFişiere ataşate:
iDj3_v1.03.zip [98.27 KiB]
Descărcat de 221 ori
(instructions included)
You will use a midi utility software to load the (sysex) file above.
http://www.bome.com/products/sendsx PC
""""""""""""""""""""""""""Treaba cu JAVA trebuie si aceea rezolvata.
Verifica si sa anunti daca ti-a rezolvat problema.
Bafta!
