acest model il avem in stoc si poate fi livrat de pe o zi pe alta
192 channel DMX controller
12 Scanners of 16 channels each
30 Banks of 8 programmable scenes
6 Programmable chases of 240 scenes
8 Sliders for manual control of channels
Assignable joystick for ease of channels
File Dump allows data to be sent or received between two units
Auto mode program controlled by speed and fade time silders
Fade time/Assign fade time
Reverside DMX channels allows fixture to react in opposition to others in a chase
8 CHANNEL or 16 CHANNEL mode
Fine adjustment for joystick pan and tilt
Blackout master button
Manual Override button allows you to grab any fixture on the fly
Built in microphone for music triggering
MIDI control over banks,chase and blackout
DMX Polarity selector
Power failure memory
Dimensions:483x132x80mm
Weight:2.5kg
costa 450 de lei cu TVA inclus si poate controla cam tot ce poti avea tu nevoie
noi il folosim in instalatii de lumini din cluburi si discoteci, insa merge si pentru Dj mobili pentru ca e relativ compact.
