Acum este Sâm Iul 19, 2025 4:17 am
Scrie un subiect nou Răspunde la subiect  [ 232 mesaje ]  Du-te la pagina Anterior  1, 2, 3, 4, 5, 6 ... 16  Următorul
MesajScris: Dum Mar 12, 2006 5:05 pm
nu pot fi comparate cele 2 proiecte, sunt in categorii diferite, si de performanta si de design
MesajScris: Dum Mar 12, 2006 6:43 pm
Stiu, dar poate ar fi o solutie acest sub pt cu camere mici.
Oricum pt camere eu zic sa folositi band-pas-uri, veti avea un bas excelent, sau bass-reflex, dar nu cu acelasi rezultat in subbas.
MesajScris: Mar Mar 28, 2006 1:01 pm
Localitate: Sf. Gheorghe
M-am apucat de 2 Subwoofere deja. Urati-mi noroc baieti.
Le voi face din MDF si cu difuri Selenium. Au nevoie de un amp. mai mare decat P. Audio dar sper sa mearga tare.
Pentru cei care vor sa faca cutia dar nu au un cutsheet i-l aveti aici:
Desigur pentru cei care vor merge la ateliere va fi mai folositor.
Nu voi folosi manere de Al sau ABS ci - am furat ideea de la Dynacrd - voi folosi manere "facute in cutie".
Vibrate the air around you!!!
MesajScris: Mar Mar 28, 2006 1:17 pm
Succes, sa ne spui cum suna :wink:
MesajScris: Vin Apr 07, 2006 12:08 am
Robi-Ka scrie:
:lol: :lol: :lol:
O sa cam muncesti pe manere !
MesajScris: Vin Apr 14, 2006 10:36 am
Can anyone recalculate the ports for 18Sound 18W800 driver please.
Thank you.
Regards
MarjanM
MesajScris: Sâm Apr 15, 2006 7:17 pm
It looks like no modifications need to be made to the project for your driver 8)
MesajScris: Lun Apr 17, 2006 8:34 am
MarjanM scrie:
Thank you.
Regards
MarjanM
Hello MarjanM,
18Sound 18W800 is a very good driver.
It will perfom very well and this loudspeaker design it is apropiate for this speaker.
I didn't work with this model but I have a friend how use this model into an original F18PWH clone design.
Actually, he told me that it perfom better than EVX-180 ( original driver for F18PWH ).
In my opinion, I think that you must tune the loudspeaker a litle bit higher to be perfect for your 18 Sound speaker.
It is very easy.
Make the ports a litle bit shorter than our design .
47 cm will be perfect.
Pay attention at maximum power.
18W800 is rated only for 400w - cont. power. If you want to push very hard, set the limiter to limit hard the higher level than 500 ~ 600w rms.
Ultima oară modificat de Dan Nita aka DNA pe Lun Apr 17, 2006 9:00 am, modificat 1 dată în total.
Localitate: Hermosillo, Sonora, Mexico
And for LX60 from Beyma ?? :oops:
MesajScris: Lun Apr 17, 2006 8:53 am
Poteiros©Corp scrie:
Yes.
Beyma 18LX60 have similar parameters.
Anyway, will perform with very small diferences, but is not a problem.
Should be a problem only for drivers with Fs bigger than 42 ~ 45Hz ,
or QTS > 0,4.
Anyway, if you use an High pass filter at 30Hz ( 18dB/oct) it would be safer. Generaly speaking.
This Beyma driver is a very good driver, too, in the same performance level like Paudio C18-600, or 18Sound 18W800.
It is very hard to make comparations between brands, becouse this design sound very well with a lot of pro speaker. Off course, maybe will sound with small particular coloration, but this design it was made for pro-use.
MesajScris: Mar Apr 18, 2006 9:09 am
Thank you very much guys :D
How much increase in sensitivity shoud i expect from this box comparing to a common Bas Reflex box?
Ragards.
MarjanM
P.S. I might come to Romania this year. There is one agency here offering 8 days "Dracula Tour" visiting Transilvania. :wink:
MesajScris: Mar Apr 18, 2006 7:43 pm
MarjanM scrie:
Ragards.
MarjanM
well, this design does not increase the spl in the subbass range (it behaves like a regular bassreflex below 50Hz) , the real gain is a little higher in frequency
above 50Hz it starts to gain directivity, thus inceasing the spl
the gain can be around 3-4db compared to the regular bassreflex
MesajScris: Mar Mai 23, 2006 9:46 pm
moderator
am o intrebare pt HP 18W ce modificari trebuie facute sau nu e bun diful pt acest "BOOMBOX" :P
MesajScris: Vin Mai 26, 2006 10:12 am
se poate folosi si pt hp-18W
va trebui probabil schimbat putin acordajul
voi face cateva calcule si voi posta modificarile necesare
MesajScris: Dum Iun 11, 2006 9:18 pm
M-am tot uitat pe forum si nu sunt sigur de un lucru:
am inteles ca proiectul acesta de planar horn aduce un castig de 3-4 db fata de un BR clasic. In graficul prezentat de catre Dynacord se observa un castig de 6 dB. Concluzia este ca proiectul de aici coboara mai jos in schimb are un SPL mai scazut datorita amplasarii rezonatoarelor in exterior?
