Acum este Mar Iul 15, 2025 5:26 pm
Scrie un subiect nou Răspunde la subiect  [ 162 mesaje ]  Du-te la pagina Anterior  1 ... 4, 5, 6, 7, 8, 9, 10, 11  Următorul
MesajScris: Lun Aug 20, 2007 9:40 am
I see you had your hands busy 8) ...
Those tops are the ones from the plan you asked earlier? You used the orignial speakers from the plan (c12 300mb+bm d450)?
http://www.Midnight-Events.ro
@ex pitbull_bog
MesajScris: Lun Aug 20, 2007 10:47 am
pitbull_bog scrie:
no this tops are from Bcorde.com from FRANCE:
Beyma SM-212 + DE10 + ME10 from B&C Speaker
2 voies bass reflex - 400 watts AES - BP : 45Hz-20KHz - 98db 1w/1m.
http://www.bcorde.com/index.php?page=83&lg=1
SORRY!!!
MesajScris: Lun Aug 20, 2007 12:52 pm
pitbull_bog scrie:
a little precision: it's not my planar and my top, these photos are from a french forum of DIY. :oops: http://fr.audiofanzine.com/membres/index,idmembre,269745,page,photos.html
MesajScris: Mar Aug 21, 2007 9:37 am
fabrizio971 scrie:
pitbull_bog scrie:
SORRY!!!
after a test session in France we think that this top is ok with a pair of long planar( one top for two planar in long version with a rcf 's speaker inside ) for information 8)
MesajScris: Vin Aug 24, 2007 6:49 am
Has nobody an idea whether these drivers work in the planar wave horn ?
18Sound 18LW1400
http://www.eighteensound.it/index.aspx? ... ct&pid=197
or
Oberton 18XB700
http://www.oberton.com
MesajScris: Dum Aug 26, 2007 11:24 pm
fabrizio971 scrie:
18Sound 18LW1400
or
Oberton 18XB700
Nexus said :
I know that P-audio c18-650EL works in this design , but you have to shorten the ports by 110 milimeters
But i checked the webpages. In the specs i found diffrent specs on different websites. 1) vas: 230 liters 2) Vas : 158 lit
Finally i checked at p audio, then it is different. 3) paudio : 170 lit
So i want to ask him what specs nexus got for this driver for the suggestion of using it in planar wave horn?
MesajScris: Lun Aug 27, 2007 12:41 pm
the sugestion is valid for the C18-650EL that was manufactured in the past 3 years
MesajScris: Mar Oct 02, 2007 10:33 am
cea de aici este mai buna,
dar asta este cea mai buna:
:wink:
pt c18 trebuie scurtate tuburile cu 110mm
totusi recomand selenium 18sw1P pt senzatii extreme...
Salut , am cumparat si eu 2 HP-18s si as vrea sa fac 2 incinte si vreau sa stiu ce dimensiuni trebuie sa aibe tuburile la proiectul acesta.Multumesc anticipat.
MesajScris: Mie Oct 03, 2007 10:09 am
scurtezi porturile cu vreo 100 mm
MesajScris: Mie Oct 03, 2007 7:03 pm
Multumesc,cind o sa le termin o sa pun niste poze.
MesajScris: Mie Oct 03, 2007 7:28 pm
frumos Imagine
MesajScris: Joi Oct 04, 2007 8:50 am
si e hand-made :wink:
MesajScris: Mar Oct 23, 2007 3:33 pm
Salut , dupa cum am promis am facut si eu poze la cele 2 planare cu difuzoare HP-18S.Le-am facut din MDF de 18mm dar din lipsa de bani capacele din spate si panoul pe care se prinde difuzorul a trebuit sa le fac din pal.
http://tinypic.com/view.php?pic=1pgjtv&s=2
http://tinypic.com/view.php?pic=1zppnpk&s=2
http://tinypic.com/view.php?pic=eaqoms&s=2
http://tinypic.com/view.php?pic=20h4wtu&s=2
http://tinypic.com/view.php?pic=dfuk46&s=2
http://tinypic.com/view.php?pic=2m26kxu&s=2
http://tinypic.com/view.php?pic=2s97gd3&s=2
Satelitii sunt echipati cu Eminence delta-15lfa,un driver cu bobina de 2" si un tweteer (niste chinezarii care or sa fie schimbate cand o sa mai am capital).
Costul total pentru planare a fost de aprox. 12 mil cu totul.
Despre cum se aud ..... o mica cearta cu vecinii, doar la jumatate din puterea unui singur difuzor,spune totul.
Multumiri lui Nexus si lui DNA pt forum si pentru schite.
MesajScris: Mar Oct 23, 2007 3:50 pm
Felicitari !!!
As avea o intrebare? ce vopsea ai folosit ? (am mai vazut facute cu genu asta de vopsea doar pe speakerplans)
Si inca ceva: cate kg au ?
@ex pitbull_bog
MesajScris: Mar Oct 23, 2007 3:52 pm
Localitate: Zalau/Cluj
frumos...cam cate kg are un planar?
Music is my drug
