Acum este Sâm Iul 12, 2025 2:35 am
Scrie un subiect nou Răspunde la subiect  [ 162 mesaje ]  Du-te la pagina Anterior  1, 2, 3, 4, 5, 6 ... 11  Următorul
MesajScris: Vin Dec 29, 2006 11:17 pm
Localitate: Braila
La versiunea scurta, pt a se utiliza Hp18w, ce dimensiuni vor avea porturile?
MesajScris: Mie Ian 10, 2007 8:44 pm
Localitate: Bulgaria
hello from me:)
i need help for calculate this plan for use another 18" speaker
i mean 18sound 18lw1400 how calculate at bass-reflex or not?
MesajScris: Dum Ian 14, 2007 10:24 am
Localitate: Medias
ma poate ajuta cineva si pe mine cu proectul de la versiunea scurta?
MesajScris: Dum Ian 28, 2007 10:50 pm
found on speakerplan : long version with C18650el
MesajScris: Dum Ian 28, 2007 10:52 pm
long version, it works also with precision device pd 1850 ( found on speakerplans)
MesajScris: Mie Feb 14, 2007 10:08 pm
Localitate: Bistrita
Am o intrebare un difuzor SAL spa5070 de18'' ar merge pt un horn planar...?
Pz / W 250
Pn / W 180
Z / Ω 8
fs / Hz 36
f / Hz 25-2200
fx / Hz 1000
Spl / dB 93
∅ / inch 2,5
RDC / Ω 7,7
Sd / cm2 1164,0
Qms 4,94
Qes 1,32
Qts 1,04
VAS / l 221,56
Mms / g 160,73
Rms / kg/s 8,17
Cms / mm/N 0,12
BxL / Tm 14,10
L / mH 1,29
∅ / mm 456
∅ / mm 422
MesajScris: Mie Feb 14, 2007 10:14 pm
NU
MesajScris: Joi Feb 15, 2007 2:09 am
MasterG scrie:
Pz / W 250
Pn / W 180
Z / Ω 8
fs / Hz 36
f / Hz 25-2200
fx / Hz 1000
Spl / dB 93
∅ / inch 2,5
RDC / Ω 7,7
Sd / cm2 1164,0
Qms 4,94
Qes 1,32
Qts 1,04
VAS / l 221,56
Mms / g 160,73
Rms / kg/s 8,17
Cms / mm/N 0,12
BxL / Tm 14,10
L / mH 1,29
∅ / mm 456
∅ / mm 422
la difu asta din simulari reiese ca cel mai bine ar merge o incinta seled de vreo 130L volum intern...... in BR are niste varfuri foarte mari la 60-70Hz si o sa sune naspa ......
MesajScris: Joi Feb 15, 2007 3:50 am
mie mi-a placut raspunsul lui nex in "caps" :lol: :lol: :lol:
MesajScris: Mie Iun 27, 2007 10:46 pm
the short planar nearly finished...and carpeted!! nexus3 do you like it like that? :P
MesajScris: Joi Iun 28, 2007 8:49 am
it looks very good nice work :D
MesajScris: Joi Iun 28, 2007 9:01 am
fabrizio971 scrie:
welcome to the club 8)
MesajScris: Mar Iul 10, 2007 12:49 am
fabrizio971 scrie:
two planar made with the french version of the plan as you see there is another one in france who is verry happy to use your idea
thanx a lot 2 DJ DNA or NEXUS 3
MesajScris: Mar Iul 10, 2007 9:37 pm
In sfarsit un sub pe forumul asta in care nu o sa sune tobele lui tata guta nicolae :wink:
MesajScris: Mar Iul 10, 2007 9:58 pm
yes, I saw that plan a while ago on audiofanzine :wink:
nice build
