Acum este Lun Iul 21, 2025 7:05 am
Scrie un subiect nou Răspunde la subiect  [ 81 mesaje ]  Du-te la pagina Anterior  1, 2, 3, 4, 5, 6  Următorul
MesajScris: Sâm Sep 13, 2008 10:06 am
Product : Neutrik Speakon - NL4FX
* Connector Type Speakon
* Gender female
Electrical
* Contact resistance < 2 mΩ (after lifetime)
* Dielectric strength 4 kVdc (peak)
* Insulation resistance > 1 GΩ (after dampheat)
* Rated current per contact 40 A rms continuous
* Rated current per contact 50 A audiosignal, duty cycle 50%
* Rated voltage 250 V (Insulation)
Mechanical
* Cable O.D. 7 - 14.5 mm
* Cable retention force ≥ 220 N (subject to cable O.D. and material)
* Lifetime > 5000 mating cycles
* Wire size 4 mm² / 6 mm² (screw type terminals/soldering)
* Wire size 12 AWG / 10 AWG
* Wiring screw type terminals or soldering
* Locking device Quick Lock (latch)
Material
* Bushing Polyamide (PA 6 15% GR) black
* Contact plating 4 µm Ag
* Contacts Brass (CuZn39Pb3)
* Insert PBTP 20 % GR
* Locking element Zinc diecast (ZnAl4Cu1)
* Shell PBTP 20 % GR
* Strain relief Polyacetal (POM)
Environmental
* Approvals UL,cUL
* Flammability UL 94 HB
* Solderability Complies with IEC 68-2-20
* Temperature range -30 °C to +80 °C
MesajScris: Sâm Sep 13, 2008 10:36 am
adi, nu se compara cu un surub strans, dar e ok pt curentii care intra prin difuri.
MesajScris: Sâm Sep 13, 2008 11:15 am
Sharky scrie:
da
sincer la asta ma gandeam si eu
ca daca pun 2 papuci pe cablu si leg la curu` statiei - pai am acolo suprafata de contact de 2 hectare :lol:
DNA scrie:
acum - m-am mai linistit
MesajScris: Sâm Sep 13, 2008 11:22 am
Localitate: Sogndal
da, cu strip de iesire cu speakon si cabluri cu 4 fire (trimiti simultan semnal se medii si inalte separate activ, cum avem noi in sistem)
Da, acum capata sens. M-am mai linistit si eu :) .
MesajScris: Sâm Sep 13, 2008 12:39 pm
La nex e diferit , ceea ce are el facut acolo deja e altceva 8) El are defapt facut ceea ce au vrut si cei de la neutrik sa fie facut , cand au pus 4 pini in mufa :wink: :lol:
Bridge s-ar putea sa gasesti intre +1 si +2 , sau stiu eu , ce alte combinatii au facut unii :roll: .
Oricum , +1 si -1 , legarea mono. Si daca stai sa te gandesti putin , prin mici modificari poati face orice combinatie de plus-uri si minus-uri la care te poti gandii :lol:
MesajScris: Sâm Sep 13, 2008 12:48 pm
Localitate: Sogndal
Da, da Alex, sa stii ca ai dreptate cu legarea in bridge pe 1+ si 2+, ca ma uitam ieri in cartea tehnica a amplificatoarelor Samson, seriile SX. Si asta m-a indus in eroare.
http://www.samsontech.com/products/prod ... rodID=1800
Na, ca am mai invatat ceva.
Ma taie rau sa-mi iau un SX 1800 8) .
MesajScris: Sâm Sep 13, 2008 4:23 pm
Cat costa? Poate poti lua altceva mai bun in banii aia :)
MesajScris: Sâm Sep 13, 2008 4:33 pm
Localitate: Sogndal
Pai am vazut la "MagazinulDeMuzica" la acelasi pret cu MAX 2500
Na, tot in categoria low cost intra; stiu eu ce sa zic... (!?)
MesajScris: Joi Sep 18, 2008 12:58 am
black_knight scrie:
toata lumea vorbeste de SPK-ON, le foloseste ... dar cine stie care e suprafata de contact intre mufe
adica - suprafata de contact intre mufa mama si cea tata
eu ma tem ca nu este prea mare
de ce zic asta - pt ca am stricat niste chinezarii si am observat ca bucatile de metal din interior nu sunt prea mari
are cineva date tehnice cu privire la aceasta problema ?
mnoh - nu-mi fac griji la puteri de pana la 200-300 W unde curentii sunt mici, dar la 1 KW deja discutam altfel, ca e vorba de curenti de peste 10-11 A
PS: sa nu sariti pe mine ca mufele Neutrik originale au alta configuratie in interior ca nu-i adevarat
tot aceeasi structura au
Mai sapa putin si vei gasi speak-on-urile pe 8 poli 8) ...ca sa nu mai zic de mufele tip speak-on pentru alimentari cu 3 poli..foarte misto :P
MesajScris: Joi Sep 18, 2008 1:22 am
Catalin_Gava scrie:
dynacord-ul vostru are specoane pe 8 poli, m-am uitat cu adi in iasi la ele de aproape. :D
MesajScris: Joi Sep 18, 2008 2:32 am
Catalin_Gava scrie:
Le zice powercon :lol:
MesajScris: Joi Sep 18, 2008 10:31 am
Sandu_Alex_999 scrie:
Catalin_Gava scrie:
ezact :D
http://www.thomann.de/gb/neutrik_nac3fcb_powercon.htm
http://www.thomann.de/gb/neutrik_nac3mpa_powercon.htm
MesajScris: Joi Sep 18, 2008 11:16 am
black_knight scrie:
am tras si 3 KW RMS in 2 ohmi (curent garla) prin NL4C si nu au puscat.
SPEAKON pana la moarte :twisted:
MesajScris: Joi Sep 18, 2008 11:18 am
rms cu muzica?
MesajScris: Joi Sep 18, 2008 11:21 am
teste cu sinus de 50Hz (generator de ton din AMIC DSP) pe DPA4000T
