Acum este Dum Iul 06, 2025 11:12 pm
 Subiectul mesajului: P-audio PH-170
MesajScris: Joi Oct 15, 2015 12:49 pm
Mai jos va prezentam poze cu hornul P-audio PH-170.
Acest horn poate fi achizitionat din magazinul nostru on-line accesand acest link:
http://www.poweraudio.ro/difuzoare_prof ... ?filter=50
Description:
The PH-170 is an elliptical wave guide high frequency horn. The PH-170 features a 1 inch (25.4mm) throat design that is compatible with bolt on high frequency drivers. Many of the new P Audio PreNeo and BMD series professional drivers are compatible with the PH-170. The rated coverage pattern is 90 degree horizontal by 65 degree vertical. This pattern and the horns small physical size make it ideal for small foreground and background music reinforcement sound systems typically found in restaurants and retail locations. The PH-170 is constructed from high impact ABS with glass fill to provide a high degree of structural support for the compression driver.The PH-170 is ideally mated to 10 inch, and 12 inch low frequency loudspeakers. The acoustic loading allows the horn to be used down to 1200Hz. The PH-170 may be used with the following P.audio professional compression drivers. ( or any industry standard compatible driver ) - BM-D440 - BM-D450 - PreNeo-450N - PA-DE34
IMG_9557.JPG [ 213.84 KiB | Vizualizat de 4850 ori ]
IMG_9558.JPG [ 217.21 KiB | Vizualizat de 4850 ori ]
IMG_9559.JPG [ 176.62 KiB | Vizualizat de 4850 ori ]
IMG_9560.JPG [ 203.25 KiB | Vizualizat de 4850 ori ]
IMG_9561.JPG [ 253.95 KiB | Vizualizat de 4850 ori ]
