Acum este Dum Iul 13, 2025 7:02 am
 Subiectul mesajului: Amplificatorul ASHLY KLR-4000
MesajScris: Mar Sep 04, 2012 8:44 am
Localitate: campulung muscel
http://i50.tinypic.com/2rh5op3.jpg
http://i49.tinypic.com/14sksd3.jpg
http://i45.tinypic.com/2e1evwj.jpg
Power Rating
850W/Channel @ 8 Ohms Stereo
1400W/Channel @ 4 Ohms Stereo
2000W/Channel @ 2 Ohms Stereo
4000W @ 4 Ohms Bridged Mono
Damping Factor
380
Input Sensitivity
Not Specified by Manufacturer
Input Impedance
12 kOhms, Balanced
Gain 36dB Frequency Response
20Hz - 20kHz
Signal-to-Noise Ratio
109dB
Total Harmonic Distortion (THD)
< 0.05%
Connectors
2 x 3-Pin Euroblock Inputs
2 x XLR/TRS Combo Inputs
2 x Neutrik Speakon Outputs
Controls and Indicators
2 x Level Control Knobs
2 x 3-Position Gain Switches
1 x 3-Position Mode Switch
1 x 3-Position HPF Switch
1 x Limiter Switch
1 x On/Off Switch
LEDs for Level, Clip/Protect, and Power
Cooling
Variable Speed Fan, Front-to-Rear Airflow, Removable Dust Filters
Power Consumption
1.05A, Idle
Power
Permanently-Attached 3-Prong IEC Cable
Operating Temperature
14 to 104°F (-10 to +40°C)
Humidity: 0 to 90%
Protection
Output Over-current, DC Output, Chassis Temperature, Mains Breaker
Dimensions (WxHxD)
19 x 3.5 x 16" (482 x 88 x 407mm)
Weight
26.4 lbs (12kg)
5265 RON
 Subiectul mesajului: Re: Amplificatorul ASHLY KLR-4000
MesajScris: Mar Sep 04, 2012 9:02 am
Sa inteleg ca este posesorul unui asemenea produs.
Poti sa ne spui parerea ta despre el?
MesajScris: Mar Sep 04, 2012 12:33 pm
Am sa postez masuratorile ce au rezultat in urma testelor cu dynacord lx 3000,qsc plx 3402 ,ashly klr4000.....
ca si constructie e foarte ok.....cred ca suna si bine,deoarece am observat ca e o copie a lui qsc...
Masuratorile pe osciloscop ,cu semnal curat arata astfel :
pe partea de medi la 1khz-----1350 w / canal / 4 ohmi
pe partea de inalte la 16 khz---1270 w / 4 ohmi / canal
pe partea de bass la 36 Hz----1300 w / 4 ohmi / canal
Alimentare comuna ptr. ambele canale
Limitarea foarte buna dupa masuratori , insa muzical nu-mi pot da seama cum se comporta aceasta limitare...
Tot montajul este lucrat pe capacul de sus pentru a nu se aseza praful .
De asemeni la 165 V se intrerupe....in principiu raport calitate pret foarte convenabil...lucrat foarte bine....cred ca e o copie a QSC-ului.....
Amplificatorul QSC PLX 3402
De asemeni si la acest amplificator limitarea foarte buna , la fel nu stiu cum se comporta aceasta limitare.
La acest amplificator producatorul da 3400 wati in bridge si 2 x 1700 / 2 ohmi
Aprox. la 165 V se intrerupe....
Amplificatorul Dynacord Lx 3000
pe partea de medi la 1khz-----1450 w / canal / 4 ohmi
pe partea de inalte la 16 khz---1350 w / 4 ohmi / canal
La acest amplificator ,pe partea de inalte limitarea este foarte ok , insa de la 300 hz , limitarea intra mai lent , neavind timp suficient sa limiteze , strica semnalul .
Acest amplificator are alimentare separata pentru fiecare canal , dealtfel testat merge pina la aprox 150 Volti.
Concluzia mea ( nu sint un specialist , dar am fost de fata cind s-au facut masuratorile , impreuna cu userii Garbari Victor si Tony Holter ) :
Mi sa parut foarte ok si ca limitare , ca ton , ca forta , amplificatorul QSC PLX 3402 ( cu toate ca eu detin un LX 3000 ).
Avantajul LX - ului.....forta mai mare.......nu pune problema la tensiune mica.....si foarte bine lucrat...
Nu vreau sa laud nici unul din ele....concluziile le trageti voi......vreau si parerea specialistilor......
Multumesc.....
Ultima oară modificat de ionica radu pe Joi Sep 06, 2012 10:09 am, modificat de 3 ori în total.
MesajScris: Vin Oct 21, 2016 9:49 am
Amplificatoarele Ashly KR.... pe 2 ohmi sint stabile ?
Calitatea sunetului contra Qsc - Plx ?
