Acum este Sâm Iul 05, 2025 11:34 pm
 Subiectul mesajului: Dap Audio Tas 2400
MesajScris: Lun Sep 08, 2014 6:15 pm
Localitate: Cluj - Napoca
pret magazin 850 E.... ceva pareri despre acest amplif ?
Output Power, 1000 Hz, THD+N at 1%,
Both Channels Driven:
Stereo mode: 8ohm: 2x 800 Watt RMS
4ohm: 2x 1330 Watt RMS
2ohm: 2x 1920 Watt RMS
Bridge mode: 8ohm: 2660 Watt RMS
4ohm: 3840 Watt RMS
Frequency Response: 10 - 20,000 Hz, -1 dB
THD+N: < 0.05%
Damping Factor at 8ohm: > 300
Slew Rate: > 20 V/S
Signal to Noise Ratio: > 100 dB A-weighted
Input Sensitivity (Selectable): 775 mV~, 1 V~,
1.4 V~
Max Input Voltage: +22 dBu
Input Impedance: 20 k? Balanced
10 k? Unbalanced
Subsonic Filter (Selectable): 30 Hz, 18 dB/oct
Protection: Clip Limiter (Fixed)
Short Circuit
Input Overload
Output Overload
DC Voltage
High Temperature
Soft Start
Output Modes (Selectable): Stereo / Parallel
/ Bridge
Cooling: Multi Speed Fan
Airflow: Front to Back
Input / Link Connector: XLR / XLR
Output Connector: 2x Speakon,
2 Pair Bindings Posts
Groundlift Switch: Yes
Dimensions (LxWxH): 483 x 455 x 89 mm
Net Weight: 14.06 kg
Power Supply: 240 V~, 50 Hz
Main Fuse: 18AT, 6 x 32 mm
Power Consumption (2 x 4ohm): 3565 Watt Így is ismerheted: TAS 2400, TAS2400
Imagine`
 Subiectul mesajului: Re: Dap Audio Tas 2400
MesajScris: Joi Oct 23, 2014 7:05 pm
Amplificator facut de catre SAE China si distribuit sub mai multe brand-uri gen Lexon, Elmuz etc. Sunt amplificatoare bune si rezistente.
