Acum este Dum Iul 06, 2025 4:55 pm
 Subiectul mesajului: behringer EP2500 vs. Tapco J-2500
MesajScris: Vin Apr 06, 2007 5:38 pm
salutare tuturor,
vreau sa akizitionez un amplif, si la banii astia am de ales intre cele doua.
voi ce parere aveti ?
care ar fi mai bun ?
bugetul e de 12 m lei..
MesajScris: Vin Apr 06, 2007 5:51 pm
sunt cam exact la fel... :roll:
poti sa iei oricare dintre ele
mare atentie ca puterile trecute nu sunt tocmai reale
da un search pe forum dupa EP2500 ca sa vezi la ce ma refer, (s-a mai discutat) :wink:
MesajScris: Vin Apr 06, 2007 7:25 pm
Un mic plus pentru Tapco
MesajScris: Vin Apr 06, 2007 8:05 pm
Localitate: Cluj - Napoca
Tapco e stabil in 4 ohmi in bridge?
de scris scrie, da'.. :roll:
Inca ceva: dupa cum arata pe interior parca nu bate vantu' ca-n behringer, trafu pare mai serios..
MesajScris: Vin Apr 06, 2007 9:50 pm
cum e tapco ?
ca behringer are in specificatii 5 A la 230 V :(
leam cerut celor de la behringer pe site la suport on line o explicatie, si iata ce miau raspuns :
"Rate Power output Exceeds Stated Power consumption Question How can the rated power output be equal to the stated power consumption ? Answer The power consumption is calculated from the maximum constant current which can be drawn from the mains supply. However, the amplifier will only develop its maximum output power when the input signal is (a) at its maximum level and (b) contains signal across the entire frequency range. During a normal performance, this will only happen for a relatively small percentage of the overall time in use - while current is being drawn constantly from the mains supply. The output stages and power supply are designed in such a way that they can 'store energy', and release it again on demand. For short periods of time, the unit can deliver power well in excess of the nominal stated values without damage to any of its components. The rated output power is measured under very specific test conditions. These conditions state how much signal, what type of signal, how long the amplifier must be tested and at what level, and how much distortion (THD) may be tolerated. The test signals are either a 1kHz sine wave or a full-range pink noise - which are far more demanding than any 'real music' signals."
in concluzie, ce trebuie sa avem in vedere ?
puterea transformatorului? puterea rms , care vad ca nu e specificata...
daca ar fi asa cum zic ei ( 2.5kw), atunci cu un IPA300v2 de la vasile ar trebui sa scoatem 1kw/4ohm dupa specificatiile lor
:shock:
pe'dealta'parte , stie cineva niste preturi finale de akizitie la amplifurile astea doua?
paici prin bucuresti am gasit behringer'ul asta la 12 m lei; tapco iese pe la 10 m lei pe sait la ei...
MesajScris: Vin Apr 06, 2007 10:23 pm
Pe ce site? :| In germania e 365 eur.. 12 mil.. de tapco zic..
MesajScris: Sâm Apr 07, 2007 7:59 am
Phonic MAX 2500 Endstufe, 2x 750W / 4 Ohm
e mai bun decit behringer EP2500 ?
citeam pe forum ca ar avea tref de 2500va... totusi e ceva, fata de ep2500 cu 1200va
MesajScris: Sâm Apr 07, 2007 10:11 am
Localitate: Bucharest
Phonicul este mai bun ca Behringer-ul, s-a mai discutat de N ori aici pe forum.
La 300E(pret in Germania), Phonic-ul nu are adversar.
Ordinea ar fi cam asa.
1. Tapco by Mackie sau Phonic (eu zic ca sunt egale avand in vedere pozele din interior)
2. Behringer
Tapco este cu 65Eur mai scump, eu nu m-as arunca pe el...as lua Phonic fara nici o discutie.
