Acum este Mar Iul 08, 2025 9:47 am
 Subiectul mesajului: ASHLY KLR3200. CUNOASTE CINEVA ACEST AMPLIFICATOR ?
MesajScris: Vin Iul 27, 2012 9:34 am
Localitate: CAMPULUNG
Putere 2 x 1100W @ 4 ohmi
Intrari Jack / XLR
Iesiri Speakon
Unitati Rack 2U
Power Rating 650W/Channel @ 8 Ohms Stereo
1100W/Channel @ 4 Ohms Stereo
1600W/Channel @ 2 Ohms Stereo
3200W @ 4 Ohms Bridged Mono
Damping Factor > 380
Input Sensitivity Not Specified by Manufacturer
Input Impedance 12 kOhms, Balanced
Gain 33dB
Frequency Response 20Hz - 20kHz
Signal-to-Noise Ratio > 109dB
Total Harmonic Distortion (THD) < 0.05%
Connectors 2 x 3-Pin Euroblock Inputs
2 x XLR/TRS Combo Inputs
2 x Neutrik Speakon Outputs
Controls and Indicators 2 x Level Control Knobs
2 x 3-Position Gain Switches
1 x 3-Position Mode Switch
1 x 3-Position HPF Switch
1 x Limiter Switch
1 x On/Off Switch
LEDs for Level, Clip/Protect, and Power
Cooling Variable Speed Fan, Front-to-Rear Airflow, Removable Dust Filters
Power Consumption 0.92A, Idle
Power Permanently-Attached 3-Prong IEC Cable
Operating Temperature 14 to 104°F (-10 to +40°C)
Humidity: 0 to 90%
Protection Output Over-current, DC Output, Chassis Temperature, Mains Breaker
Dimensions (WxHxD) 19 x 3.5 x 16" (482 x 88 x 407mm)
Weight 24 lbs (10.9kg)
 Subiectul mesajului: Re: ASHLY KLR3200. CUNOASTE CINEVA ACEST AMPLIFICATOR ?
MesajScris: Vin Iul 27, 2012 11:54 am
Este un produs din gama celor de la Phonic , Behringer , Alto etc .
Adica tot semiPro , un fel de gunoaie , dar mai spalate .
Aici aveti producatorul real : http://www.inter-m.com/en/product/produ ... aamplifier
Nu recomand...
MesajScris: Sâm Iul 28, 2012 11:26 am
http://www.ashly.com/klrseriesamplifi.html.
Va inteleg si va multumesc pt sugestie.
Nu spun ca e cea mai buna putere,insa ieri am testat-o la cantare live.
Mi-a lasat o impresie deosebita.
Super puterea.
Inadevar este o putere cu pret mic in jur de 800 dolari insa eu am constatat ca merita fiecare cent.
Nu cred ca se compara cu Behringer sau cu Alto.
Intradevar ati spus bine.
Mai spalata.
Mult mai spalata.
MesajScris: Sâm Iul 28, 2012 2:26 pm
Ce-mi place treaba asta cu " ieri am testat-o la cantare live mi-a lasat o impresie deosebita. super puterea " ... si asa apar tot soiul de amplificatoare laudate cum ca ar fi cele mai cele , le cumpara le folosesc la unu , doua evenimente si gata incep sa le laude ( ba chiar " nu cred ca se compara cu behringer sau cu alto ... mai spalata. mult mai spalata... " si asa mai departe ) , de zici ca le-au folosit ani buni de zile si nu au avut probleme cu ele !
Si mai sunt "unii" care inainte sa le vanda deschid un topic si incep sa dea din ei ... cele mai adevarate domnule .
Sper sa nu te superi pe mine ...dar un amplificator cat de bun sau nu este se poate spune in timp nu dupa "o cantare" . :)
Daca tot vrei sa faci ceva pune niste poze cu interiorul la " The inside story " .
Cu stima !
MesajScris: Sâm Iul 28, 2012 9:38 pm
Acest amplificator este construit cu simt de răspundere si reprezinta o clasa intermediara între amplificatoarele de înaltă calitate si chinezismele de pe piața noastră .
Probabil este cel putin bun , dar nu-l recomand deoarece inca am rezerve datorită faptului ca nu am făcut masuratori pe acest model si nu am informații detaliate despre cum se comporta la tensiunea variabila a rețelei de 230V ac din România ...
Nu cunosc care este reactia utilizatorilor .
Nu cunosc care este rata de defectare , cum este asigurat service-ul dpdv al pieselor de schimb etc .
Am doar o schema din care rezulta ca este o simpla semiclona de QSC ( de fapt are finali mai multi decât QSC , sunt fabricati de Sanken nu de Toshiba , ceea ce reprezintă un mare plus fata de QSC si clonele asiatice ...) , dar si Behringer este o clona de QSC .
Nu putem pune egal între QSC si Behringer sau alti producatori chiar dacă folosesc aceeași schema !
Contează materialele folosite , proiectul , experiența producătorului etc .
MesajScris: Lun Iul 30, 2012 5:30 am
A scris domnul Victor............
Probabil asta este cauza ca aceasta putere suna excelent.(testata live)
In privinta fiabilitatii sunt puteri cu garantie in Romania.
Multumesc dl Victor pt sfaturile care le dati membrilor forumului.
Multa stima
MesajScris: Mie Aug 01, 2012 8:45 am
Povestea este mult mai complicata decat la prima vedere.
unul din factorii de maxima importanta la orice echipament PRO, este fiabilitatea. Fara acesta informatie nu putem decide cat de bun este un amplificator decat strict prin prisma peformantelor masurate efectiv.
Ecler a avut nevoie de 5 ani de zile pentru a se impune pe piata din Romania , cei 5 ani fiind necesari pentru a urmari comportamentul in timp al produselor.
MesajScris: Joi Aug 02, 2012 7:33 am
Localitate: campulung muscel
Confirm , un prieten detine un amplificator ecler de aprox. 5 ani.....nu a avut nici cea mai mica problema...
Concluzia , ....amplificatoarele ecler sint foarte fiabile .........
Utilizatorii ce navighează pe acest forum: Majestic-12 [Bot] şi 1 vizitator
