Acum este Mar Iul 15, 2025 8:06 pm
 Subiectul mesajului: despre RCF HPS 2500
MesajScris: Vin Mar 18, 2011 12:00 am
Localitate: Braila
salutare.
stie cineva ceva despre RCF HPS 2500? sau...imi puteti spune daca merita banii astia? (2900 lei) as dori sa amplific 2 boxe RCF ART 725 (sonorizari NBC)
AMPLIFIER SPECIFICATIONS
Power output stereo 2Ω: 2x 1400 Watt RMS
Power output stereo 4Ω: 2x 1100 Watt RMS
Power output stereo 8Ω: 2x 700 Watt RMS
Power output bridged 4Ω: 2800 Watt RMS
Power output bridged 8Ω: 2200 Watt RMS
Frequency Response: 20 Hz ÷ 20 kHz
THD @ 1 kHz: 0.05 % , 1 dB below clip
Signal / noise rate: 106 dB
Damping factor @ 8 Ω > 300
Slew rate: 50 V/μS
INPUT SECTION
Input connector: XLR
Input sensitivity: 1.4 dBm/V RMS
Input impedance: 20 kΩ (balanced), 10 kΩ (unbalanced)
OUTPUT SECTION
Output connector: Speakon
SYSTEM PARAMETERS
Cooling: Forced
Voltage gain: 32 – 26 dB
Amplifier class: H
POWER REQUIREMENT
Operating voltage: 220 ÷ 240 V (50 / 60 Hz) V ~ Hz
PHYSICAL SPECIFICATIONS
Height: 88 mm
Width: 482 mm
Depth: 420 mm
Net Weight: 19 kg
multumesc
