Acum este Vin Iul 18, 2025 9:37 pm
 Subiectul mesajului: alegere amplificator subwoofer
MesajScris: Vin Apr 04, 2008 4:55 pm
Localitate: eterna romanie
voi ce ati alege?
mentionez ca amplificatorul va fi folosit pe 2 subwoofere 150W rms 8 ohm cu un behringer cx2310
1:Tapco J800
http://www.tapcoworld.com/pdf/Juice_SS.pdf (atentie specificatiile ptr j800)
poza : http://www.dv247.com/assets/products/32400_l.jpg
sau
2: W-Audio (Warrior) SB-850 - ceva mai scump
http://www.bluearan.co.uk/sales/warrior ... /AMP23.jpg
* Features Rated power bridge mode (8 Ohms): 850 Watts
* Rated power (2 X 4 Ohms): 425 Watts per channel
* Rated power (2 X 8 Ohms): 300 Watts per channel
* Controls: Two front panel volume controls, rear panel mode switch and gain select switch
* Cooling: Two temperature dependant 40mm high output DC fans
* Indicator LED's: 2 Clip, 2 signal presence, 1
* Bridge and 1 active status/Protection
* Protection: Thermal and DC
* Inputs: XLR
* Outputs: Speakon and Binding Post
* Specifications Power Supply: 230v
* Dimensions: 44 mm x 483 mm x 350 mm
* Weight: 15kgs
