Acum este Mar Iul 15, 2025 1:52 am
 Subiectul mesajului: P-audio PHT-411
MesajScris: Joi Oct 15, 2015 2:18 pm
Mai jos va prezentam poze cu tweeterul cu horn P-audio PHT-411.
Acest tweeter poate fi achizitionat din magazinul nostru on-line accesand acest link:
http://www.poweraudio.ro/difuzoare_prof ... ?filter=23
Description:
The PHT-411 is a rectangular geometry high frequency integrated horn and driver that features a 100 degree horizontal by 40 degree vertical radiation pattern. This design features a constant directivity style horn and offers a rated bandwidth of 2kHz to beyond 16kHz. The PHT-411 offers a very high sensitivity of 105dB when measured with a one watt input at a distance of one meter making the device an excellent mid range and ultra high frequency device in two way sound reinforcement systems. The PHT-411 is ideal when used with a 12 inch or 15 inch low frequency transducer in a two way design. The integrated horn and driver is used in many professional two way designs. The PHT-411 utilizes a small format 1 inch (25.4mm) diameter diaphragm assembly that is optimized for extended piston range response The PHT-411 is ideal as a high frequency device for portable high performance sound reinforcement systems. The device is constructed of a very rigid glass reinforced ABS resin that offers both superior structural support as well as excellent mechanical damping.
IMG_4060.JPG [ 74.4 KiB | Vizualizat de 5141 ori ]
IMG_4061.JPG [ 121.48 KiB | Vizualizat de 5141 ori ]
IMG_4063.JPG [ 124.98 KiB | Vizualizat de 5141 ori ]
IMG_4064.JPG [ 103.9 KiB | Vizualizat de 5141 ori ]
IMG_4065.JPG [ 101.58 KiB | Vizualizat de 5141 ori ]
IMG_4066.JPG [ 101.77 KiB | Vizualizat de 5141 ori ]
IMG_4067.JPG [ 90.49 KiB | Vizualizat de 5141 ori ]
IMG_4068.JPG [ 95.77 KiB | Vizualizat de 5141 ori ]
