Acum este Lun Iul 14, 2025 11:48 pm
 Subiectul mesajului: Procesor LD systems x 233
MesajScris: Sâm Dec 03, 2022 12:26 pm
Buna ziua ,
Va rog sa ma ajutati cu o parere despre acest procesor . A folosit cineva ?
Product type Signal Processors
Version 2-way stereo/3-way mono
Frequency response 20 - 20.000 Hz
Dynamic range 106 dB
Signal-to-noise ratio > 93 dB
Total Harmonic Distortion (THD) < 0.004 %
Crosstalk < - 80 (20 - 20.000 Hz) dB
Max. input level +21 (balanced or unbalanced) dBu
Max. output level +21 (balanced or unbalanced) dBu
Input impedance (kOhms) 50000 kOhm
Output impedance 200 Ohm(s)
Controls 2 x crossover frequency low/high, 2 x crossover low/mid, 2 x high gain, 2 x highpass (40 Hz), 2 x input gain, 2 x low gain, 2x frequency switch x1/x10, 4 x inv switch, LF sum, Mono/stereo mode
Indicators 2 x clip, 2 x crossover x 10, 2 x highpass, 4 x inv., mono, stereo
Line inputs 2
Line input connectors XLR
Line outputs 4
Line output connectors XLR
Mains connector IEC socket
Operating voltage 220 V AC - 240 V AC
Width 482 mm
Height 44.5 mm
Depth 153 mm
Weight 2,6 kg
Multumesc anticipat!
419D45A4-8359-456F-B719-0EFC38D71CBE.jpeg [ 118.32 KiB | Vizualizat de 2003 ori ]
 Subiectul mesajului: Re: Procesor LD systems x 233
MesajScris: Dum Dec 04, 2022 9:29 pm
Îi un crossover, nu-i un procesor.
Țin să cred că CX de la Behringer îi peste acest LD :)
MesajScris: Lun Dec 05, 2022 8:35 pm
Buna seara ,
Multumesc de raspuns . Efectiv am dat copy paste . N am avut , n am folosit .
Sunt curios daca a avut cineva , daca a folosit cineva . As dori o parere .
Multumesc anticipat .
