Acum este Vin Iul 18, 2025 1:06 pm
 Subiectul mesajului: PUTERE SUPORTATA
MesajScris: Vin Sep 05, 2014 8:41 am
Localitate: Suceava
Buna ziua
Vreau sa-mi spuneti din expierienta dv la ce putere se pot folosi wn-urile (wn18n) pe difuzor scrie 500w 8 ohmi! Am achizitionat un amplificator LD SYSTEM ultima serie:
Specificatii pentru LD-Systems DEEP2 2400 X:
Product type: power amplifier
Type: 2-channel
Rated ouput power (1kHz @ 2 Ohms): 2 x 1200W
Rated ouput power (1kHz @ 4 Ohms): 2 x 950W
Rated ouput power (1kHz @ 4 Ohms, bridged): 2200W
Output circuitry: Class H
Frequency response: 20 - 20000Hz
THD: < 0,1 %
Crosstalk: >76dB
Gain: 39dB
Input sensitivity: 0,775
Protection circuits: DC protection, short circuit, clip limiter, thermal overload
Controls: 2 x highpass/lowpass (switchable), bridge/stereo mode selector, ground lift, mains switch (on/off), 2 x volume
Display: level, signal, limit, protect (protection circuit engaged), Power
Loudspeaker outputs: 2
Speaker output connections: Terminal posts, Speakon compatible
Cooling: highly efficient, automatic
Operating voltage: transformer, 230 V AC / 50-60 Hz
Weight: 17,6kg
Daca leg in paralel boxele sa merg in 4 ohmi suporta 950w ?
 Subiectul mesajului: Re: PUTERE SUPORTATA
MesajScris: Vin Sep 05, 2014 8:55 am
suporta fara probleme
oricum puterea RMS in toata banda de frecventa va fi undeva pe la 700 de W pe acel amplificator la 4 ohmi
Daca te uiti , ei declara puterea la 1000 de Hz ceea ce le mareste artificial valorile obtinute.
marketingul asta... :roll:
MesajScris: Vin Sep 05, 2014 9:24 am
Localitate: Suceava
Multumesc mult, concluzia e ca vanzarile de electronice au ajuns ca promisiunile in politica! :(
MesajScris: Vin Sep 05, 2014 9:33 am
cam da :roll:
trebuie sa casti bine ochii inainte sa dai banii
putini mai sunt corecti in ziua de azi...
