Acum este Mar Iul 01, 2025 4:51 am
 Subiectul mesajului: Reparatie Turbosound TCS35 - boxe 8inch
MesajScris: Vin Ian 26, 2024 11:55 pm
Salut,
Cu ce as putea inlocui inalta la boxele Turbosound TCS35? Inalta este "TW-509" 1” (25mm) HF tweeter si are 100mm diametru si seamana cu Beyma T-2030.
http://warehousesound.com/r/turbosoundTCS35.pdf
 Subiectul mesajului: Re: Reparatie Turbosound TCS35 - boxe 8inch
MesajScris: Sâm Ian 27, 2024 12:59 pm
Dupa specificatii, poti pune un t-2030 de la Beyma
Il avem in stoc
Verifica inainte de toate, sa incapa fizic.
MesajScris: Sâm Ian 27, 2024 9:52 pm
Dispersia la Beyma T-2030 pare sa fie doar 60 grade HxV, iar a boxei de 120 grade. Ceva nu pusca aici.
Va trebui sa frezez probabil 2mm ca sa incapa.
120°H x 120°V @ -6dB - Average over stated bandwidth
The TCS-35 is a compact trapezoidal passive 2-way
loudspeaker for use in a variety of fixed installations
such as pubs, cafés, bars, restaurants and clubs.
It consists of an 8” low frequency driver and
a 1” titanium high frequency tweeter
matched with a third order internal passive
crossover network in a trapezoidal cabinet.
The TCS-35 features a wide (120° x 120°)
dispersion pattern which allows it to be used
in a variety of nearfield, background and
surround sound applications. It can also be
used as a delay speaker in a larger sound
reinforcement system
MesajScris: Dum Ian 28, 2024 2:29 pm
nu mi-as face griji in privinta dispersiei
