Acum este Sâm Iul 05, 2025 12:43 pm
 Subiectul mesajului: I'm back !
MesajScris: Mie Mar 15, 2006 2:54 pm
I.ve been schetching away one day, and came up with an interesting ideea
it's a horn loaded mid top
1x12" P-audio C12-300MB
2x6.5" Eminence LA6-CBMR - CLOSED BACK 6.5" MID SPEAKER
2x1" driver probably P-audio WN-D44
I'll post a pic of the internal layout scetch
until then , I'm posting the mid-bass and mid plots
Mid horn: 2 pi (2 horns on one enclosure)
midbass horn (2 horns in a horizontal or vertical array)
the high frequency horn ideea came up when I seen the new horn P-audio had developed for line arrays
The part I like is the fact that the mid-hi section can be couplet both verticaly and horizontaly to form any coverage necesary without too much comb filtering, if any
and of couse it's again extremely compact 8) , because It's my obsession :twisted:
MesajScris: Mie Mar 15, 2006 4:43 pm
That looks very good. I'd like to see some more detailed pictures.
Looks almost too good to be true at that size?
MesajScris: Mie Mar 15, 2006 4:55 pm
Yes I know , I can't belive it myself
and the good part is that the more enclosures togheter, the more smooth the response is :wink:
4 enclosures in a vertical array, would be extremely cheap, and would have a great coverage and SPL.
the HF and MF horns can be made of wood , relatively simple
I can't wait for the summer to come so I can start experimenting...
I'll scan the schetches as soon as I can
MesajScris: Dum Mar 19, 2006 11:58 am
MesajScris: Lun Mar 20, 2006 1:35 am
oh right!... i get it now.
i couldn't visualise the layout before... i like the figures too, although the high mid might give you something to work on.
james.
mardy hippy.
MesajScris: Lun Mar 20, 2006 6:47 am
Localitate: Hermosillo, Sonora, Mexico
Very, very good work.
What will be the dispertion of the box ??
Cheers
MesajScris: Lun Mar 20, 2006 9:48 am
I presume something like 60 degree horizontal and 20 vertical - depending of the waveguide
the interesting part is that if you put two boxes side by side with one of the units upside down the HF and MF sections will line up next to each other , thus coupling ang giving us a 90 degree dispersion, cool eh? :wink:
the design originated from a line array I was triyng to desigh, but I soon discovered that I was be able to split it into a pair of enclosures.
MesajScris: Joi Mar 23, 2006 11:15 pm
Localitate: paris france
very very good design
i have just few questions about the mid high horn
-where did you find this p audio line horn because i know a shorter model model from b&c but i didn't find this one?
-do you want to build from wood this horn for the comp driver too
-finally i woold like to know where we can find the eminence driver
thanks a lot nexus
you drived me to this forum a few month ago when i would built a mid top with hd15 in it and i follow the topics since and i have understood a lot of things about horn loading
and now i 'm still a newbie but i can follow the movement of Ceharden
James ,ind and you
jon
MesajScris: Vin Mar 24, 2006 12:34 am
EMOTYPE scrie:
on www.paacoustic.com , it's one of the new products
Yes, i think wood will be more simple , and cheap
ask them:
http://www.laboitenoire.net/boite/grill ... 16&fam=251
they don't seem to have it on stock, but you can mail them and ask.
thanks a lot nexus
James ,ind and you
jon
I am glad you had something to learn from here
MesajScris: Vin Mar 24, 2006 11:05 am
Localitate: oradea
"where did you find this p audio line horn because i know a shorter model model from b&c but i didn't find this one? "
check here -> http://www.paacoustic.com/Product_Detai ... D=PH-14525
MesajScris: Vin Mar 24, 2006 11:26 am
Localitate: oradea
this makes me thinking...
how u can go low enough with wn d44 thus u will be able to reach to uppercut frequency of the mid horn?
its hard to cut a 1" driver under 2khz... a 2" driver should be a better option...
MesajScris: Vin Mar 24, 2006 12:33 pm
the mid section should easily reach 3 Khz
!! hornresp does not plot corectly higher in frequency, that's why the graph posted seems to fall so sharply.
a 2" driver is not an option because of the size
MesajScris: Vin Mar 24, 2006 2:00 pm
thanks a lot
i have just one suggestion that will not be aproved by nexus
why don't do it larger..
my idea is to have the mid high section on mobile area
i explain
to stack the cabs in more position why don't we place the mid high section in a square cab where we could displace it horizontaly or verticaly in fonction of the show
we could fix it with btr screw on a chassis and it would be easy to have the same dispersion when the cab is down or up.....
jon
[/img]
MesajScris: Vin Mar 24, 2006 5:05 pm
interesting ideea, I'll study it for a while to see how it can be done :wink:
MesajScris: Mar Mar 28, 2006 1:45 pm
i have an idea about it but i don't have scanner to show you what i had in my mind
i will post it when!
another things :
why dont make it trapezoidal on the other side too with the same degrees
it will revolution the concept that you work for but it will be more easy to array in all positions
i have draw all of that but i couldn't model a horn in horn response i still haven't work on it
but the idea is here and the dimensions are tight from other product or try from this forum
thanks for your attention
i wil post it in a few days
jon
