Acum este Mie Iul 02, 2025 11:46 pm
Scrie un subiect nou Răspunde la subiect  [ 16 mesaje ]  Du-te la pagina Anterior  1, 2
Trapezoidal cabinet?
Trapezoidal 88%  88%  [ 43 ]
Non-trapezoidal 12%  12%  [ 6 ]
Voturi totale : 49
MesajScris: Vin Ian 06, 2006 4:29 pm
Localitate: Rotterdam / Holland
Okay Graeme, thanks for the explanation.
What you are saying is that it might work for over ~400 Hz, but not below.
And thet for the lower freq's it does not really matter, no dispersion control, but no problems either. correct?
The only thing that could be a disadvantage then is that because of the wider dispersion under 400, we have less efficiëncy there too, so the box will go a bit louder (in the narrower field of) over 400 and not under 400?
It might sound "thin" as a result then.
I knew there had to be a catch somewhere, :idea: it was too simple to be true.
But the box is not built yet, and it will take some more time too!
cul8r!
Experience is something you don’t get until just after you needed it.
