Acum este Sâm Iul 05, 2025 8:13 am
 Subiectul mesajului: Cea mai puternica boxa din lume
MesajScris: Joi Noi 11, 2010 12:29 am
Aveti aici link catre cea mai puternica boxa creata pana acum
http://www.danleysoundlabs.com/pdf/JH90 ... 0sheet.pdf
151 dB in regim program per bucata
It uses six 18-inch low-frequency drivers, six 6-inch mid-frequency drivers, and two 4-inch two-way high-frequency drivers, making it a four-way design.
Users have the option of adding 20,000 Watts of self-power and/or user-adjustable DSP.
The combination of the three Danley technologies enable a single Jericho Horn to supply even coverage out to multiple hundreds of feet.
This is accomplished as Shaded Amplitude Lens Technology allows as much as 20 dB of gain out of a single cabinet, to be evenly distributed over a very large listening plane.
The unique performance of Jericho Horn, is the product of Tom Danley, who has a unique approach to loudspeaker design.
“In every respect, the Jericho Horn is a vastly better alternative to the problematic line array solution that the industry has ‘settled’ for,” said Mike Hedden, president of Danley Sound Labs.
“Its output is monstrous, yet so pleasant to listen to. There is nothing comparable on the planet. I challenge any line array solution, at any price, to even approach the Jericho Horn’s performance.”
“This is reference quality typically only heard at close distances, yet being delivered at hundreds of feet away.”
“It occurs to me that for a time, slide rules were indispensable to engineers, physicists, and others who worked with numbers; but then something better came along, and they don’t use slide rules anymore. It will come as no surprise that I view line arrays as the slide rules of the sound reinforcement industry.”
 Subiectul mesajului: Re: Cea mai puternica boxa din lume
MesajScris: Joi Noi 11, 2010 9:45 am
Kenwood cand iti tragi doua din astea ? :lol:
Hmm 320 kg ! :?
Cu doua bucati cred ca acoperi 2-3 mii de oameni.
MesajScris: Sâm Noi 13, 2010 3:27 am
:D
cred ca ar merge o varianta , de criza , cu 6x12 inchi pe joase......doar ca amuzament !
