Acum este Dum Iun 01, 2025 11:45 am
Reguli forum
 Subiectul mesajului: Phonic MAX 1500
MesajScris: Sâm Oct 24, 2020 8:38 pm
Vand Phonic MAX 1500
Il am de vreo 6 ani, folosit pe 2 fullrange de 300W 8 Ohm.
Intretinut foarte bine, desfacut periodic pt curatat.
Trimit in tara doar cu plata transport in avans.
Putere de iesire: 2 x 280 W/ 8Ω, 450 W/ 4Ω
Mod bridge: 900W 8Ω
Conectori: intrari: XLR; iesiri: Speak-on si borne de prindere
Amplificare clasa H.
Raspuns in frecvente: 20 Hz-20KHz, +0/-1dB; -3dB points: 5Hz-50KHz
Rear panel: Slide switches: Limiter On/Off, Operation mode: Parallel, Stereo, Bridge Mono, Current reset break switch
Protectie: scurt-circuit, termica, subsonica, protectie RF, Output DC offset, Power on/off muting
Consum de putere: 900W
Dimensiuni: 482 x 88 x 415mm (19” x 3.46” x 15.9”)
Greutate: 11.15 kg (24.6 lbs)
Pret: 750 lei
tel: 0745021392 Bogdan
122598191_1503103009875325_7779107549888366067_n.jpg [ 79.84 KiB | Vizualizat de 6561 ori ]
122454848_351693626092396_2177628518308348294_n.jpg [ 66.52 KiB | Vizualizat de 6561 ori ]
