Acum este Joi Iul 03, 2025 11:27 am
Reguli forum
 Subiectul mesajului: Placa sunet profesionala studio RME Fireface 800
MesajScris: Mie Mai 31, 2023 11:32 am
Vand placa de sunet profesionala RME Fireface 800.
Placa a fost folosita in regim home studio.
Pret: 2100 lei usor negociabil.
Specificatii tehnice:
Input AD: 8 x 1/4" TRS, 4 x XLR Mic, 4 x 1/4" TRS Line, all servo-balanced. 1 x 1/4" TS unbalanced
Output DA: 8 x 1/4" TRS, servo-balanced, DC-coupled signal path. 1 x 1/4" TRS unbalanced
Input Digital: 2 x ADAT optical or SPDIF optical, SPDIF coaxial (AES/EBU compatible)
Output Digital: 2 x ADAT optical or SPDIF optical, SPDIF coaxial (AES/EBU compatible)
MIDI: 1 x MIDI I/O via 5-pin DIN jacks, for 16 channels low jitter hi-speed MIDI
Dynamic range AD: 109 dB RMS unweighted, 112 dBA
THD AD: -110 dB ( 0.00032 %)
THD+N AD: -104 dB ( 0.00063 %)
Crosstalk AD: > 110 dB
Dynamic range DA: 116 dB RMS unweighted, 119 dBA (unmuted)
THD DA: -103 dB ( 0.0007 %)
THD+N DA: -100 dB ( 0.001 %)
Crosstalk DA: > 110 dB
Input/Output level for 0 dBFS Hi Gain: +19 dBu
Input/Output level for 0 dBFS +4 dBu: +13 dBu
Input/Output level for 0 dBFS -10 dBV: +2 dBV
Sample rate internally: 32, 44.1, 48, 64, 88.2 kHz, 96 kHz, 128, 176.4, 192 kHz
Sample rate externally: 28 kHz - 200 kHz
Frequency response AD/DA: -0.1 dB: 5 Hz - 21.5 kHz (sf 48 kHz)
Frequency response AD/DA: -0.5 dB: 5 Hz - 43.5 kHz (sf 96 kHz)
Frequency response AD/DA: -1 dB: 5 Hz - 70 kHz (sf 192 kHz)
IMG_0222.jpg [ 152.29 KiB | Vizualizat de 11481 ori ]
IMG_0221.jpg [ 90.43 KiB | Vizualizat de 11481 ori ]
IMG_0220.jpg [ 105.41 KiB | Vizualizat de 11481 ori ]
IMG_0219.jpg [ 97.47 KiB | Vizualizat de 11481 ori ]
IMG_0218.jpg [ 94.59 KiB | Vizualizat de 11481 ori ]
 Subiectul mesajului: Re: Placa sunet profesionala studio RME Fireface 800
MesajScris: Joi Dec 14, 2023 11:24 am
Se poate inchide, multumesc.
