Acum este Vin Iul 18, 2025 7:31 am
 Subiectul mesajului: Power mixer
MesajScris: Vin Sep 25, 2009 3:23 pm
Localitate: Oras Teius Jud. Alba
Ce parere aveti despre aceste 2 mixere low cost? Care spuneti ca este mai bun din ori ce punct de vedere?
1. http://i37.tinypic.com/2eai6xf.jpg
Specificatiile :
THE T.MIX PM184X II
the t.mix PM184X II compact powered mixer - 2x375W/4Ohm, 2x200W/8 Ohm, new updated built-in FX processor with 32 effects (reverb, chorus, flanger, delay), 7-band graphic EQ, 6 mono Inputs (1/4" jack) with 3-band mid-sweep EQ & low cut, 4 stereo Inputs (1/4" jack) with 4-band EQ, 2+2 subgroups (1/4" jack), 2 aux sends, 2 aux returns (1/4" jack) , stereo tape in/out (Cinch), speaker outputs with Speakon connectors. Includes 19" rack mounting kit. Approx, dimensions: 51x48x10-19cm. Weight: 21kg
2. http://i38.tinypic.com/11mc64h.jpg
BEHRINGER PMP 1000
BEHRINGER PMP 1000 powered mixer, 12 channels (6 mono. 2 stereo), power 2x 250W/4 Ohm (500W bridge), 24bit multiFX prozessor with 100 presets, FBQ feedback elimination, 6 mic preamps witt 48V phantom power, 3-band EQ with LowCut filter and clip LED at each mono channel, 7-Band stereo EQ für master and monitor, 3D stereo surround effect, adjustable AUX in, stereo preamp outs, internal power supply, 8 kg, dim: h x b x t 122 x 390 x 425 mm
Multumesc.
X4nd3R
