Acum este Mie Iul 16, 2025 8:31 am
 Subiectul mesajului: Beyma 6G40Nd
MesajScris: Joi Oct 15, 2015 9:01 am
Mai jos va prezentam poze cu difuzorul Beyma 6G40Nd.
http://www.poweraudio.ro/difuzoare_prof ... ?filter=13
TECHNICAL SPECIFICATIONS
Nominal diameter 165 mm 6.5 in
Nominal impedance 8 ohm
Minimum impedance 7 ohm
Power capacity 170 W AES
Program power 340 W
Sensitivity 95 dB 1 W @ 1m @ 2Π
Frequency range 70-9000 Hz
Recommended enclosure volume 10 / 30 l 0.35 / 1.06 ft.³
Voice coil diameter 51.7 mm 2 in
BL factor 11 N /A
Moving mass 0.012 kg
Winding length 9 mm
Air gap height 7 mm
Xdamage pp 20 mm
THIELE SMALL PARAMETERS
Fs 88 Hz
Re 6.2 ohm
Qms 9.1
Qes 0.34
Qts 0.33
Vas 7.2 l
Cms 260 µm / N
Rms 0.76 kg / s
Efficiency % 1.4
Sd 0.014 m²
Xmax 1 mm
Vd 14 cm³
Le @1 kHz 0.6 mH
CONSTRUCTIVE DETAILS
Net weight 1.7 kg 3.74 lb
Total weight 2.3 kg 5.06 lb
Magnet Neodymium
IMG_3137.JPG [ 212.29 KiB | Vizualizat de 3286 ori ]
IMG_3138.JPG [ 197.97 KiB | Vizualizat de 3286 ori ]
IMG_3139.JPG [ 226.81 KiB | Vizualizat de 3286 ori ]
IMG_3140.JPG [ 227.18 KiB | Vizualizat de 3286 ori ]
IMG_3141.JPG [ 231.62 KiB | Vizualizat de 3286 ori ]
IMG_3142.JPG [ 250.93 KiB | Vizualizat de 3286 ori ]
IMG_3143.JPG [ 214.82 KiB | Vizualizat de 3286 ori ]
IMG_3144.JPG [ 236.83 KiB | Vizualizat de 3286 ori ]
IMG_3145.JPG [ 270 KiB | Vizualizat de 3286 ori ]
IMG_3146.JPG [ 283.25 KiB | Vizualizat de 3286 ori ]
