Acum este Vin Iul 04, 2025 12:25 pm
 Subiectul mesajului: Beyma 18P1000Fe
MesajScris: Joi Oct 15, 2015 8:52 am
Mai jos va prezentam poze cu difuzorul Beyma 18P1000Fe.
TECHNICAL SPECIFICATIONS
Nominal diameter 460 mm 18 in
Nominal impedance 8 ohm
Minimum impedance 6.2 ohm
Power capacity 1000 W AES
Program power 2000 W
Sensitivity 98 dB 1 W @ 1 m
Frequency range 25-2000 Hz
Recommended enclosure volume 80 / 200 l 2.8 / 7 ft³
Voice coil diameter 100 mm 4 in
BL factor 26 N / A
Moving mass 0.215 kg
Winding length 21 mm
Air gap height 12 mm
Xdamage pp 52 mm
THIELE SMALL PARAMETERS
Fs 40 Hz
Re 5.1 ohm
Qms 15.11
Qes 0.4
Qts 0.39
Vas 163.2 l
Cms 75 µm / N
Rms 3.61 kg / s
Efficiency % 2.5
Sd 0.1250 m²
Xmax 8 mm
Vd 1000 cm³
Le @1 kHz 2.8 mH
CONSTRUCTIVE DETAILS
Net weight 12.9 kg 28.38 lb
Total weight 14.4 kg 31.68 lb
Magnet Ferrite
IMG_1633.JPG [ 220.77 KiB | Vizualizat de 3444 ori ]
IMG_1634.JPG [ 231.54 KiB | Vizualizat de 3444 ori ]
IMG_1635.JPG [ 243.13 KiB | Vizualizat de 3444 ori ]
IMG_1636.JPG [ 231.5 KiB | Vizualizat de 3444 ori ]
IMG_1637.JPG [ 259.19 KiB | Vizualizat de 3444 ori ]
IMG_1638.JPG [ 180.09 KiB | Vizualizat de 3444 ori ]
IMG_1639.JPG [ 179.04 KiB | Vizualizat de 3444 ori ]
IMG_1640.JPG [ 290.18 KiB | Vizualizat de 3444 ori ]
IMG_1641.JPG [ 199.49 KiB | Vizualizat de 3444 ori ]
IMG_1642.JPG [ 200.01 KiB | Vizualizat de 3444 ori ]
