Acum este Dum Iul 06, 2025 5:50 pm
 Subiectul mesajului: Beyma 12MI100
MesajScris: Joi Oct 15, 2015 9:30 am
Mai jos va prezentam poze cu difuzorul Beyma 12MI100.
http://www.poweraudio.ro/difuzoare_prof ... ?filter=16
TECHNICAL SPECIFICATIONS
Nominal diameter 300 mm 12 in
Nominal impedance 8 ohm
Minimum impedance 8 ohm
Power capacity 450 W AES
Program power 900 W
Sensitivity 100 dB 1 W @ 1 m @ 2Π
Frequency range 40-4000 Hz
Recommended enclosure volume -
Voice coil diameter 77 mm 3 in
BL factor 21.6 N / A
Moving mass 0.047 kg
Winding length 13.5 mm
Air gap height 10 mm
Xdamage pp 24 mm
THIELE SMALL PARAMETERS
Fs 58 Hz
Re 6.3 ohm
Qms 5.54
Qes 0.23
Qts 0.22
Vas 64 l
Cms 163 µm / N
Rms 3.3 kg / s
Efficiency % 5.1
Sd 0.053 m²
Xmax 2 mm
Vd 105 cm³
Le @1 kHz 2.3 mH
CONSTRUCTIVE DETAILS
Net weight 7.2 kg 15.8 lb
Total weight 7.3 kg 16.06 lb
Magnet Ferrite
IMG_9574.JPG [ 251.63 KiB | Vizualizat de 3385 ori ]
IMG_9576.JPG [ 177.81 KiB | Vizualizat de 3385 ori ]
IMG_9577.JPG [ 126.64 KiB | Vizualizat de 3385 ori ]
IMG_9581.JPG [ 255.9 KiB | Vizualizat de 3385 ori ]
IMG_9583.JPG [ 197.47 KiB | Vizualizat de 3385 ori ]
IMG_9585.JPG [ 227.6 KiB | Vizualizat de 3385 ori ]
IMG_9586.JPG [ 214.92 KiB | Vizualizat de 3385 ori ]
IMG_9588.JPG [ 205.2 KiB | Vizualizat de 3385 ori ]
IMG_9589.JPG [ 229.94 KiB | Vizualizat de 3385 ori ]
