Acum este Sâm Iul 19, 2025 10:29 am
 Subiectul mesajului: Fx 20
MesajScris: Dum Feb 19, 2012 8:34 pm
Merg parametrii acestui difuzor in fx20?
Nominal Diameter 460 mm (18 in)
Nominal Impedance 8 ohm
Minimum Impedance 6.3 ohm
Continuous Power
Handling
2400 W
Nominal Power Handling
(AES)
1200 W
Sensitivity (1W/1m) 98 dB
Frequency Range 35 - 1000 Hz
Voice Coil Diameter 100 mm (4 in)
Winding Material Copper
Former Material Glass Fibre
Magnet Material Neodymium Inside Slug
Winding Depth 25 mm (1 in)
Magnetic Gap Depth 12 mm (0.5 in)
Flux Density 1.2 T
Surround Shape Triple Roll
Cone Shape Radial
Magnet Type Neodymium Inside Slug
Design
Spider Double Silicone
Pole Design T-Pole
Recommended
Enclosure vol
160 dm3 (5.65 ft3)
Recommended tuning
freq.
37 Hz
Fs 31 Hz
Re 5.1 ohm
Qes 0.27
Qms 4.2
Qts 0.26
Vas 252 dm3 (8.9 ft3)
Sd 1210 cm2 (187.6 in2)
EtaZero 2.7 %
Xmax +- 9 mm
Xvar +- 11 mm
Mms 211 g
Bl 28 Txm
Le 1.7 mH
 Subiectul mesajului: Re: Fx 20
MesajScris: Mie Feb 22, 2012 8:59 pm
Localitate: Lugoj
Daca e vorba de B&C 18NW100 eu as zice ca merge....adaugi ranforsari si e ok....(personal as face cutia din lemn stratificat...si atunci nu mai ai probleme sigur)
