Acum este Mar Iun 17, 2025 10:44 pm
 Subiectul mesajului: zenith schematic needed
MesajScris: Sâm Apr 15, 2006 5:50 pm
i agree no having to deal with drama friends of mine always make such big deals out of inconsequential matters like not knowing the truth who cares? if you don't know the truth and people are fee
advantage of revealing the presence of mutation that is the cause of sickle cell Field performance of transgenic elite
Akira's stand mixer is selling at only $19.90 but quality is not so fantastic. There a few brands but of smaller capacity. I have a small Kenwood stand mixer which cos abt $50. Or you cld try phili
I checked out the parts book quite carefully when I put together the shopping list for my conversion from Speedlines to spoked wheels The 1978 parts book shows both types of wheels and there seems t
Ultima oară modificat de jokedy pe Mar Sep 07, 2010 3:34 pm, modificat de 2 ori în total.
 Subiectul mesajului: Re: petra-toroid
MesajScris: Sâm Apr 15, 2006 5:59 pm
jokedy scrie:
Stie cineva ce se intampla cu situ de la petra-toroid ? incerc de 2 zile sa trimit un e-mail si nu pot..o sa icerc luni sa-i contactez telefonic!! daca are cineva idee ce se intampla de nu pot trimite e-mail va rog sa-mi spune-ti si mie...!! si inca o intrebare.. :D : cam cat e transportul la un transformator din iasi pana in buc ? m-ar interesa si pe mine un transformator de 2x50v 400W ..pt un ipa400 si as vrea sa stiu la ce banii ma duce !! cam cat costa trasformatoru si cam cat e transportul ! ..va multumesc !!!
daca ai un singur modul ipa400 iti trebuie 2x50V@600VA 400 e putin rau ... daca ai 2 module 2x50V@1200VA (adica 50V la 12A)
MesajScris: Sâm Apr 15, 2006 6:10 pm
pai am vorbit cu vasile ..si a zis sa-mi iau de 600W daca-l folosesc in 4 ohm ! eu o sa-l folosesc pe un sigur difuzor in 8 ohmi !!! si mi-a zis sa-mi iau de 400W!!! ... ...va rog sa ma mai sfatuiti sa fac comanda de untransformator bun..sa nu iau ceva sa nu fie bun !
MesajScris: Sâm Apr 15, 2006 6:54 pm
ia de 600 mai bine, nu se stie ce vei face cu el in viitor :wink:
MesajScris: Sâm Apr 15, 2006 7:02 pm
ok ! merci :)) asa o sa fac !! ...stie cineva la ce bani ma duce ??
MesajScris: Sâm Apr 15, 2006 7:11 pm
cam astea sunt preturile de la petra :wink:
MesajScris: Sâm Apr 15, 2006 7:23 pm
merci !:)
MesajScris: Dum Apr 16, 2006 8:54 pm
ce punte redresoare mi-ar trebui ? ?? de cat sa-mi cumpar?
MesajScris: Dum Apr 16, 2006 9:10 pm
Redresarea: Punte 50A cu ceva radiator si 4x10000uF@100V .....
MesajScris: Dum Apr 16, 2006 9:35 pm
aham merci...si in caz ca pe viitor vreau sa-mi mai iau un ipa400 ?? treb sa schimb transformatorul sa-l comand 1200 ? sau pot sa mai comand unu de 600 si va merge la fel de bine??? va...rog...un sfat :)
MesajScris: Dum Apr 16, 2006 9:49 pm
mai pui unul de 600 de W alaturi de pe care alimentezi celalalt canal
este chiar mai bine asa decat cu un singur transformator comun :wink:
amplificatoarele nu se mai influenteaza reciproc la puteri mari 8)
MesajScris: Dum Apr 16, 2006 11:07 pm
cel mai bine comanzi pe cel de 1200VA asa: cu 2x50V pentru modulele de ipa400, si 2x12V pentru alte utilitare cum ar fi ..ventilatoare, protectii, vumetru .... +ca: daca iei doua trafuri de 600VA cred ca e mai scump :roll: ...cu ocazia asta vreau sa-l intreb pe nexus ..eu voi face cu traf de 1200VA si cu 12V si voi pune: 2 protectii, 1 vumetru si 2 ventilatoare de 0,5A fiecare ..e mult? ce sursa de stabilizare imi va trebui? de 2A ajunge?
MesajScris: Lun Apr 17, 2006 2:20 am
Ar trebui intai sa te gandesti cam la tot ce vei alimenta din acel stabilizator , aduni curentii consumati de toate montajele alimentare din acel stabilizator . Curentul rezultat e curentul pe care trebuie sa ti-l poata da stabilizatorul , bineinteles il faci si tu acolo sa poata da cu cel putin 30-40% mai mult curent.
Sa inteleg ca vrei sa alimentezi ventilatoarele din stabilizator ? Nu cred ca e neaparat nevoie . Daca nu o sa bagi si ventilatoarele la stabilizator eu cred ca ar ajunge si un stabilizator care poate da max 1A .
Sa vedem si parerea lui Nexus :) .
MesajScris: Mar Apr 18, 2006 8:03 pm
pare ok
MesajScris: Dum Apr 23, 2006 9:41 pm
La ipa 400 daca ii pui traf de 2x50v si 600 de W pui punte redresoare de 50 de Am si 600 W ?si la trafu de 1200 W pui punte de 50 de amperi si 1200W ?zic bine?
