Acum este Dum Iul 20, 2025 7:10 am
 Subiectul mesajului: Amplificatoare noi Phonic
MesajScris: Mar Aug 10, 2010 3:42 pm
Localitate: Praga / San Jose
Va spuneam in topicul legat de primul mixer digital de la Phonic si de un nou amplificator seria MAX de la Phonic. Nu stiu de ce nu mai apare pe site, insa gasiti in catalog(fara imagini din pacate, dar din ce am vazut in acel moment pe site, designul e acelasi "MAX Plus" dar in versiunea 3U), cateva detalii despre el:
MAX 3500
2400W Power Amp
Output power: 1200W @ 4 ohms stereo, 750W @ 8 ohms stereo
High-current toroidal transformers for greater power and low noise
Balanced XLR input on each channel
Binding post and Speakon-type outputs
Front mounted gain controls for easy access
Signal and Peak LED indicators to monitor performance
Short circuit, thermal, subsonic, RF protection, output DC offset
Power on/off muting
Grounding / Floating switch to avoid grounding loop
482.6 x133.5 x 390 mm (19" x 5.25" x 15.35") \ 21.6 kg (47.6 lbs)
Pana intra cineva in posesia lui, si vedem ce are sub copota si ce "poate" cred ca mai avem de asteptat. Totusi nu ma astept la mare lucru, o situatie gen "EP2500-EP4000" nu cred sa fie o surpriza. Ce ma face curios pe mine e marimea 3U :roll: .
Si daca Phonic a lansat un mixer digital, a lansat si un amplificator digital care la fel, nu apare pe site, nu l-am vazut cum arata, tot ce stiu sunt aceste informatii pe care le gasiti in catalogul lor 2010.
iAMP4020
4020 Watt Digital Amplifier
2010 Watts of power per channel at 2Ω
Front-mounted gain controls
Signal, -20, -10 and clip LEDs on both channels
Neutrik speakon connector used for main power input to ensure cables are not
inadvertently removed
Extremely wide frequency response achieved through digital circuitry: 10Hz – 40kHz
XLR connectors provided for signal input
Professional standard speakon connectors on output
Full range of protection circuitry with indicators: thermal, VHF (very high frequency)
and ‘protect’
Male XLR ‘link’ connectors included for parallel operation
Input gain switch: 1V, 26dB and 32 dB Rolling Eyes Rolling Eyes.
PS: Nu intentionez sa fac reclama, e doar o informatie care cred ca intereseaza pe unii.
Ultima oară modificat de Fabian David pe Mar Aug 10, 2010 4:10 pm, modificat 1 dată în total.
MesajScris: Mar Aug 10, 2010 4:09 pm
exista pe forum un user care reprezinta importatorul Phonic
poate ne poate da el mai multe detalii
in general siteurile nu sunt intretinute de fabrica ci de firme angajate, de aceea exista un delay la update-uri.
asa este si cazul nostru
avem produse care se vand de cateva luni desi nu apar pe website.
MesajScris: Mar Aug 10, 2010 4:13 pm
Eu zic ca e de bine,ca apar tot mai multi concurenti pe piata de digitale. Ceea ce ne avertiza DNA se cam intampla. E cam aceeasi situatie cum a fost la aparitia camerelor foto digitale. O perioada cu statut de "produs de lux" si apoi toata lumea le are. :?
MesajScris: Mie Aug 11, 2010 10:50 am
Localitate: Brasov
MAX3500 a fost lansat anul trecut cred.
Noi nu o sa-l aducem pentru ca la aceasi putere oferim amplificatoare din gama XP(XP3000), mai fiabile, mai puternice si cu mai multa vana, ca sa spun asa.
Cat despre iAMP4000(nu 4020), modelul asta inca este in stadiu de proiect si teste, nu a fost oferit spre vanzare(la Summit au lucrat circa 3 ani inainte sa-l lanseze), iar cand va fi disponibil il vom aduce sa vedem ce poate.
Cat despre amplificatoarele digitale: da, o sa apara tot mai multe, incercand sa egaleze performantele Lab.Gruppen(4x5000W in 2U, 12 kg), dar nu o sa se poata asa ceva. Am vazut amplificatoare digitale cu putere, dar nu aveau vana, nu aveau co*ie ca sa spun asa. Se auzeau moale, la 600-1000W.
LE: la sfarsitul anului o sa aducem mixere cu putere cu USB player si recorder. Dupa asta s-ar putea sa aducem si mixere mici(AM220/240/440) cu usb player si recorder.
Deci se anunta lucruri interesante din partea Phonic-ului...
MesajScris: Mie Aug 11, 2010 12:19 pm
Informatiile legate de iAMP4020 le-am luat din catalogul lor online 2010. Acolo asa aparea. Daca e in stadiul de proiect, inseamna ca au facut modificari. Poate de aici vine numele modificat
<<The Phonic i A M P4020 of fers a mind - blowing 4020 Watts of power in a simple, low-weight 2U construct.>>
MAX3500 e adevarat ca la un moment dat era afisat si pe site, dar apoi a disparut. :?
Ultima oară modificat de Fabian David pe Mie Aug 11, 2010 2:42 pm, modificat 1 dată în total.
MesajScris: Mie Aug 11, 2010 12:37 pm
Localitate: Brasov
In listele de preturi si in cataloagele fizice, se cheama iAMP 4000 si are 2x2000 in 2 ohm, nu 2x2010...ma rog, nesemnificativ.
MesajScris: Vin Aug 13, 2010 2:06 am
Un amplificator DIGITAL este un pic eronat ca denumire!
Asta ar insemna ca semnalul care intra in el sa fie digital si sa iasa digital.
Ori noi nu ascultam digital ci sinusoide.
:roll:
Ceva SEMI digital, at fi doar partea de DSP dintr-un amplif, adica intra semnal analogic sau digital, semnalul analog(in cazul intrarii analogice) este codat in digital, se fac toate functiile pe care le poate DSP-ul intern, dupa care semnalul este decodat in analog, si injectat etajului final, fie el clasa AB, BD, D, G, H (2 step sau 3 step), I (BCA Amplifier) sau ce clase de functionare mai sint.
In cazul ampificatoarelor IN COMUTATIE ,cum ar fi termenul corect, acestea fiind cele cu border, semnalul audio analog este modulat cu un semnal triunghiular de frecventa mare, iar la iesire, filtrarea semnalului de frecventa mare se face de catre un circuit sau mai multe L-C, raminind semnalul audio analogic dupa "filtrare" .
Deci NU exista amplificator de putere FULL digital, nici macar tripath-ul nu este PUR digital.
MesajScris: Vin Aug 13, 2010 9:31 am
Localitate: Brasov
ele sunt numite amplificatoare digitale pentru ca fac parte din clasa D care e numita digitala. si asa s-a incetatanit.
MesajScris: Sâm Aug 14, 2010 5:37 pm
Pai tocmai clasaD NU este digitala, este |Switching Amplifier|
MesajScris: Dum Aug 15, 2010 11:25 pm
Localitate: Brasov
de aia am si spus ca e "numita" digitala.
asa s-a obisnuit. Tehnic vorbind, nu sunt digitale :)
