buna ziua
nu inteleg aceste specificatii. ce putere are acest modul? se poate pune pe o boxa cu filtru ? o sa_l gasesc la 220V
Output Power:............................................................1400W (8Ohm, 100Hz, 120V)
Frequency Response:...............................................45 Hz-20kHz (350W, 8Ohm)
Total Harmonic Distortion:........................................0.05% (45Hz - 20kHz, 8Ohm)
Slew Rate:...................................................................20 V/µs
Damping Factor:.........................................................over 200 (100Hz, 8Ohm)
Signal-to-Noise Ratio:................................................98dB (unweighted)
Sensitivity:..................................................................775mV
High-pass Filter Cutoff Frequency:..........................45Hz (basic model)
High-pass Filter Slope:..............................................24 dB/oct
Low-pass Crossover Filter Cutoff Frequency:........28-250 Hz
Crossover Low-pass Filter Slope:............................12 dB/oct
Power Requirements:................................................AC120V, 50/60Hz
Weight:........................................................................8.8Lb
Dimensions:................................................................7.8" (width)
16.04" (height)
4.1" (depth)
Specificatiile la modulul de 700w sunt astea. oare sunt gresite specificatiile la modulul de 1400w ?
Output Power: 700W (8Ohm, 100Hz, 120V)
Frequency Response*: 45 Hz . 80...350 Hz (700W, 8Ohm)
Total Harmonic Distortion: 0.05% (45Hz - 20kHz, 8Ohm)
Slew Rate: 20 V/µs
Damping Factor: over 200 (100Hz, 8Ohm)
Signal-to-Noise Ratio: 98dB (unweighted)
Sensitivity: 775mV
High-pass Filter Cutoff Frequency: 45Hz (basic model)
High-pass Filter Slope: 24 dB/oct
Low-pass Crossover Filter Cutoff Frequency: 28-250 Hz
Crossover Low-passFilter Slope: 12 dB/oct
Power Requirements: AC120V, 50/60Hz
Weight: 8Lb
Dimensions: 7.8" (width) 16.04" (height) 4.1" (depth)
CE E CU SPECIFICATIA ASTA LA MODULUL DE 1400W Frequency Response:...............................................45 Hz-20kHz (350W, 8Ohm) E GRESALA ?
