Salut! Am achizitionat recent 2 Pioneer ts-w307d4 si as vrea sa le fac o incinta genul asta (
http://www.price.ro/specificatii_magnat ... _57403.htm)daca se poate , oricum ceva sa aiba bass puternic mai pe romaneste.Cine ma poate ajuta va rog cu niste calcule(dimensiuni)?o sa o pun in portbagaj-ul masinii.Aici sunt specificatiile :
size 30 cm(12") ,
nominal power 400w ,
maxim music power 1200w ,
nominal impendance dual 4 ohmi ,
sesitivity 89 dB ,
frequency response 18 Hz to 500Hz ,
magnet weight 2 400 g(83 oz) ,
displacement 0.076 cu.ft / 2.16 liters ,
Revc(ohm) dual 3.0 ,
Levc(mH) 3.55 (8ohmi) / 1.04 (2ohmi) ,
Fs(Hz) 34.8 ,
Qms 13.99 ,
Qes 0.54 ,
Qts 0.52 ,
Vas (cu.ft)(liters) 1.444 / 40.865 ,
Rms(N.S/m) 2.561 ,
Mms(g) 164.05 ,
Cms(m/N) 1.3 X 10-4 ,
Diam(inch)(mm) 9.5/242 ,
BL(T.m) 20.54 (8 ohmi)/10.27(2ohmi) ,
Xmax(inch)(mm) 0.37/9.4
Multumesc Anticipat !
