Acum este Vin Iun 27, 2025 11:49 am
 Subiectul mesajului: help for build pro bass cabinet
MesajScris: Mie Sep 20, 2006 11:17 am
Localitate: Bulgaria
hello i think use one 18" driver
eighteen sound 18lw1400
or
someting like that
i need from this box :
frequency 20Hz up to 100Hz
i use for black hip-hop
and powered with biema pa600
i need also that size in width 600 mm.
i use in big room chamber
and little times outdoor
i have 2 speaker box oberton S122 and give me with max about 123db/m
MesajScris: Mie Sep 20, 2006 11:43 am
use this plan for your speaker
MesajScris: Mie Sep 20, 2006 12:08 pm
i need for this plan
length of bass-port and give me some frequency band.
i use bass box pro with this plan and give me this
from 50Hz up to 270Hz give me 0db volume
-3db = 44Hz
and for my favourite 20Hz = -28db
and cone displacement 21.4mm for 20Hz
speaker give me Xmax = +-9mm
i love lil jon , eminem , three 6 mafia ,dmx ,metallica,rammstein
and many more)))
MesajScris: Mie Sep 20, 2006 12:29 pm
MADBOY
this is the best that this speaker can do
you will not reach 20Hz with this speaker in any box smaller than a van
MesajScris: Mie Sep 20, 2006 1:01 pm
ok , give me example for one 18" driver
for my wish
i want good reprodict for low bass
i give SOME of them songs
three 6 mafia - who run it, chiken head
eminem - go to sleep
baby - what happened to that boy
MesajScris: Mie Sep 20, 2006 1:25 pm
I really doubt that those melodies can reach lower than 35 Hz
so this subwoofer should be perfect for ypur needs
rememeber that you cannot sense the diference lower than 3 dB in SPL
so @ -6dB you can reach down to about 35 Hz, which is just fine :wink:
MesajScris: Mar Oct 03, 2006 10:08 pm
i buy this bass box
Behringer B1800X Pro
and i have good bass reproduction )))
thenks for your help
MesajScris: Mie Oct 04, 2006 10:59 am
Be carefull with those loudspeakers, you can damage them very easy, if you use the wrong amplifier, I mean to much power. These loudspeakers have a good bass reproduction but I would recomand a Peavey enclosure..for about the same money :wink:
