Acum este Vin Mar 29, 2024 2:01 pm
 Subiectul mesajului: B&C ME90
MesajScris: Joi Oct 15, 2015 8:34 am
Mai jos va prezentam poze cu hornul B&C ME90.
Acest horn poate fi achizitionat din magazinul nostru on-line urmand acest link:
http://www.poweraudio.ro/difuzoare_prof ... r=50,49,48
ME90
1.4" throat entry
80° x 60° nominal coverage
Constant Directivity
Very good loading down to 900 Hz
Specifications *
Throat diameter
36 mm (1.4 in)
Nominal coverage horizontal
80 °
Nominal coverage vertical
60 °
Cutoff frequency
0.9 kHz
Material
Cast Aluminium
Dimensions
270x270x138 mm (10.6x10.6x5.4 in)
Mounting And Shipping Info
Baffle cutout dimension
255x255 mm (8.8x8.8 in)
Net weight
1.4 kg (3.1 lb)
Shipping units
1
Shipping weight
1.9 kg (4.2 lb)
Shipping box
290x290x170 mm (11.4x11.4x6.7 in)
IMG_2208.JPG [ 250 KiB | Vizualizat de 3013 ori ]
IMG_2209.JPG [ 189.25 KiB | Vizualizat de 3013 ori ]
IMG_2210.JPG [ 217.15 KiB | Vizualizat de 3013 ori ]
IMG_2211.JPG [ 223.06 KiB | Vizualizat de 3013 ori ]
IMG_2212.JPG [ 230.2 KiB | Vizualizat de 3013 ori ]
